Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2015 Lincoln MKC 6 speed tranny
Old 10-26-2014, 11:32 AM
senix's Avatar
senix
senix is offline
Received 1,416 Likes on 1,011 Posts
So with the 2015...the escape sister there is no dipstick for the 6 speed tranny.
I have the 2.3 eb motor. There is a spot for checking the trans but it is just a cap.
So does anyone have any info on what dipstick to buy or how to actually confirm the level of fluid?
Old 10-26-2014, 02:01 PM
wptski's Avatar
wptski
wptski is offline
Page #287 of your Owner's Manual states that it doesn't have a dip stick and to be checked by a dealer "only" if you are having problems.
Old 10-26-2014, 03:56 PM
senix's Avatar
senix
senix is offline
Yeah...but there is no dipstick. I think it is a misprint.
When I take it in for its first service I will get them to show me...I am getting older but I am not blind. There is only a cap there.
Old 10-26-2014, 05:51 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
There is a plug on the driver's side of the trans near the cv joint. Take the plug out while its hot and running and fluid should drip out if its full. If it runs out its overfull and if nothing comes out then its low.
Old 10-26-2014, 06:12 PM
senix's Avatar
senix
senix is offline
Thanks for the info..explains a lot right there.
Old 10-26-2014, 09:41 PM
wptski's Avatar
wptski
wptski is offline
I mistakenly look at a MKX owner's manual and it has a dip stick but you have to remove stuff to get to it. A lube level hole like that is almost like an old manual transmission.
Old 10-27-2014, 05:06 AM
senix's Avatar
senix
senix is offline
Just an odd way of monitoring it. But I will inquire anyway when I take it in for first service if they have a way of checking in better then a flashlight on peeking into the hole.
Old 10-27-2014, 06:00 AM
Archion's Avatar
Archion
Archion is offline
GM used a similar problem in the late 90's. My 06 GT didn't have a stick either, and it had one weird a$$ service procedure. It's all part of the plan to get people back into the dealership bays.
Old 10-27-2014, 07:47 AM
senix's Avatar
senix
senix is offline
Well it will be going there a lot for awhile anyways. Lincoln now comes with an automatic maint. plan for several year.
They also have lifetime roadside assistance.
Old 10-29-2014, 06:09 AM
Archion's Avatar
Archion
Archion is offline
Just thinking here. Is that the same trans that is in the Focus? If so, it is a dual clutch by Getrag. It is supposed to be a sealed for "lifetime" service. Ford's definition of lifetime is 100k.
Old 10-29-2014, 07:37 AM
senix's Avatar
senix
senix is offline
Nope it is not the same at all...thank goodness
Old 10-31-2014, 12:07 AM
j.grif's Avatar
j.grif
j.grif is offline
The select shift trans in the focus is what could be called an automated manual, there is a clutch and heavy servos to move the shift forks, the select shift in the Escape and the MK c is a full on automatic complete with torque converter.
Bearjew253
1978 - 1996 Big Bronco
09-26-2017 10:31 AM
daveya48187
07-07-2017 01:42 AM
scottm1
02-01-2009 10:22 PM
Tyson0317
07-12-2008 10:53 AM
93RangerXL4x2
1997 - 2003 F150
07-02-2006 02:29 AM
Quick Reply: 2015 Lincoln MKC 6 speed tranny
