carb tuning help, driving me nuts...
seen your accelerator pump arm adjustment nut is tightened down a lot. inside your throttle arm their should be a plastic cam making the accelerator pump work. arm should be on cam at throttle solid and the adjustment nut should be touching the arm off bowl solid and no slop.
was watching the video again! your accelerator pump is moving late. need to move the adjustment screw back out. i think you have to much free travel in in pump arm! next is the air bleed screws 2.25 turn out means to lean. first fix pump arm adjustment. if problem still occuring and still 2.25 turn out you need make you idle air bleeds smaller. these are the 4 little bleeds on the outer corners on top of carb at venturies. quick fuel has a good tune up paige on this very scenerio. also AED carbs go over this procedure. currently working a 850 race vac scondary quick fuel and having to tune up the carb a little. in my case need to make bigger because car runs rich and need to open up the air bleeds a little to correct rich running. does you 390 run ruch or is it fine. need to confirm you don't have a restriction with in carb. what is your elevation? if sea level probably around a 69 jet to 71 jet on primarys at sea level. tunable air bleeds really help on this procedure. very familiar with tuning up carbs and drop a message if needed. PM sent.
blue04.5
33
04-03-2014 10:16 PM
mustang_gt_350
05-11-2010 07:28 AM
Argess
08-12-2009 02:56 PM
ssanto
01-05-2007 05:41 PM
