gooseneck on 1/2 ton
was just wondering if you could do it, my relative put on in his 78 f150 custom when it was new and has been pulling tripple axle trailers full of scrap, tractors, cattle and the works, i dont know how much they weigh for sure but i though that was a tad excessive for a half ton. is it cause the ford nine inch is a full floater instead of a semi-floater? or are trucks from the older years just more heavy duty? if it was doable i was thinking of getting one for my 92 thanks all
on
Yes it can be done but it doesn't increase the legal towing capacity of the truck you'll still be limited to a max trailer weight of about 6000lbs depending upon what powertrain you have.
The 9" is a semi floating axle just like the 8.8.
No.. your relative is just ignoring the the legal towing limit for his truck so it's only a matter of time before he gets busted.
My 88 F150 parts truck I bought few years ago had a gooseneck in it.
The pinion bearing was completely shot, the wheel bearings were shot, and had almost an inch of play in the gear backlash.
Had 10 leafs springs to, 5 main, 5 overloads. God knows what he was hauling with that truck, but it royally ****ed the rear end up real good.
These half tons weren't built to tow extremely heavy... the rear ends were garbage on these to start with.
Basically what Conanski said is spot on. Now as far as the style of trailor you like to pull thats up to you but the legal load limit is what you need to consider. I pull a 5th wheel with mine but keep it right at or may be slightly over the legal limit. For a camper I just preferr towing a 5th wheel, they follow and pull so much better as is the case with goose necks.
What I did for mine was I added a tranny cooler, Helwig load leveling springs, rebuilt the tranny with steel planetaries and a mild shift kit, new U-joints throughout, and now I'm building a 351 to replace the 300-6. Before everyone gets on to me about the six yes it is a low end beast up to about 55 mph but pulling that small 5th wheel of mine at 65 plus was going to blow it up. I love the six and in fact found someone who wants it to rebuild it and put it back in service.
