Reprogramming Remotes - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 04-17-2013, 11:25 PM
Kramer73's Avatar
Kramer73 Kramer73 is offline
Kramer73 is gaining momentum as a positive member of FTE.Kramer73 is gaining momentum as a positive member of FTE.
Hi Guys
Does anyone know how to reprogram our Australia F truck remotes. I have the US guide, and have tried it, but it doesn't seem to work on my F250.
My F250 is an XLT model with the factory Ford central locking and remote entry.
Thanks
Old 04-18-2013, 06:39 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
It should be the same process.
If it isn't working, disconnect your vehicle battery for at least 5mins.
If found this post in the SuperDuty forum, and it seemed to address other peoples problems:
Quote:
Originally Posted by biggbradwolf View Post
I have a 2004 F250 (4-door) and I had the darnedest time figuring this out, but if you first get in the drivers side and lock the doors, then unlock all the doors before putting the key in the ignition to perform the 8 cycles of off/on in 10 seconds (leaving the key in the "on" position on the 8th turn, the doors will lock and unlock, at which time you have 20 seconds to press any key on your fob or fobs to program them. Finally, turn the key to the off position and your key fob(s) should be programed. The dealer was of no real help on this, unfortunately. I hope this helps some folks out! Good luck!
Old 04-19-2013, 04:37 AM
Kramer73's Avatar
Thanks Adrian
Much appreciated. I will try it again.
My interior lights may have something to do with it as they only sometimes work, and this would then not tell the computer that the doors are open.
Hopefully a bit of perseverance will pay off. Stay tuned
Old 04-19-2013, 10:44 AM
When you say that your interior lights only sometimes work, does that mean they will only sometimes work in the "on" position? Or do they only sometimes work when you open the door? If its the latter, you probably just have some crap stuck on the switch in the door jamb, that stops the switch "opening" all the time. A cloth and some some degreaser should fix that.
Old 04-19-2013, 10:22 PM
Kramer73's Avatar
The interior lights only work sometimes when the door is opened. When they do work, they often stay on even when the door is shut.
Are the lights meant to stay on after the door is shut or do they go off immediately?
To clean the switch, I apparently spray some wd40 up into the door latch. Is this correct?
Old 04-20-2013, 08:20 AM
Kramer73's Avatar
Or is it better to remove the door panels to gain access to the switches, and to remove and thoroughly clean them.
Old 04-21-2013, 03:19 PM
It's part of the latch assembly in the door. Just spray lots of WD40 around there (or preferably electrical contact cleaner if you have it), and wipe all the gunk away and you should be fine. You may want to work the latches a few times as you do this to ensure they are moving correctly.
Shouldn't need to remove the latch.
Old 04-21-2013, 06:31 PM
Kramer73's Avatar
Ok thanks Adrian. If my hand brake is not hooked up to the electrical wire, will this affect how the interior lights work. Having not owned an F250 with everything working, I am unsure of the relation between handbrake and interior lights.
Old 04-22-2013, 01:23 PM
Nope. That is an entirely different circuit. What part of your hand brake isn't hooked up?
Old 05-02-2013, 12:30 AM
Kramer73's Avatar
Ok guys, so the wait is over. I have finally been able to enter the remote learning mode on my F250, so I can reprogram my remote.
It was not the normal method that most people used on their US trucks. For some reason, my F250 would not recognise the US method or sequence.
So I thought I would share the method for us aussies to use. The reason I wanted to do this was to reprogram my remote and 2 new ebay remotes.
Note to remember - When reprogramming any remotes, you must reprogram all of them as it wipes the memory when you enter the vehicle programming mode.
The sequence below worked on my aussie F250 XLT with factory central locking and remote entry.
1. Take off the grey plastic cover under the steering wheel to expose the steering shaft, foot pedals, fuse box, etc.
2. Find a small grey 2 pin DLC plug. Mine was next to my clutch pedal in the same group of wires with the OBD II plug. It has 2 wires, green with a purple trace and a black wire.
3. Use a hot wire to join them together
4. Turn your ignition on and wait approx 8 secs. The car horn will beep. You are now in the remote learning mode.
5. Press any button on the first remote. The horn will beep to indicate that it has been programmed.
6. Continue to press any button on remaining remotes to program them.
7. When finished, turn your ignition off and remove the jumper wire from the grey plug.
The drivers door must remain open when programming, and with the interior lights on.
So I was successfully able to reprogram my original Ford remote, but the aftermarket ebay remotes did not register with my vehicle.
So after all that, I now have to chase up some more remotes to try.
Old 04-28-2014, 03:00 AM
lstitt lstitt is online now
lstitt is starting off with a positive reputation.
Thanks Kramer73! I had bought a new genuine fob and could not get the 'manual' method to work. Yours did! My mate is going to try his as well now. Looks like the Ozzy trucks have a different setup?
Remote entry question mike potts 1999 to 2016 Super Duty 3 09-29-2016 12:48 PM
2008 Ford f250 keyless entry remote not working Super Duty 36 1999 to 2016 Super Duty 1 03-17-2016 12:50 AM
Aftermarket keyless entry 2002exPSD Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 02-13-2016 10:35 AM
Key Fob not programming ride_red 2004 - 2008 F150 6 06-15-2015 06:22 PM
Remote Start problems after battery jumpstart pwrstroketx 1999 - 2003 7.3L Power Stroke Diesel 9 02-26-2008 07:15 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
