2006 5.4l idling issue - Ford Truck Enthusiasts Forums
Old 04-17-2013, 11:17 PM
WorkhorseF250's Avatar
WorkhorseF250 WorkhorseF250 is offline
WorkhorseF250 is starting off with a positive reputation.
Ok so when the truck is under load or just drive, it idles as normal, but when you idle up and the truck idles back down it drops low enough that the truck starts knocking and idling rough, the only way to get the truck to run normal is to idle it back up and eased down to normal idle. Or by shutting the truck off. The oil pressure gauge drops off on occasion when this rough idling happens.
I was thinking the oil pump is on its way out, with it supplying the VCTs with not enough oil they may not be able to operate under such quick throttle changes
Any ideas would be greatly appreciated!
Thanks
Old 04-21-2013, 08:09 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I would start with cleaning the throttlebody first. If it has build-up in it, the blade can hang sometimes and have trouble keeping a good idle. If it sticks a bit and the rpm drops too low, then yes the oil pressure can drop enough to cause issues with the cam phasers.
97 f150 drops into rough idle while in drive b.hope014 1997 - 2003 F150 1 03-03-2016 08:45 AM
Need help! Engine shakes rough idle and smokes Broncoseth 1978 - 1996 Big Bronco 6 04-03-2015 09:24 AM
Lacking power, vibration at high RPM, rough idle AHermann06 6.0L Power Stroke Diesel 1 01-12-2015 05:57 AM
Intermittent Rough Idle After Towing Forest 6.0L Power Stroke Diesel 7 10-02-2014 10:53 AM
Rough idle, FICM, ICP, VOLTS or other??? LiftedBlackHD 6.0L Power Stroke Diesel 13 05-15-2014 06:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
