Better Towing MPG - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Better Towing MPG
Old 04-17-2013, 07:49 PM
RedHorseFarm's Avatar
RedHorseFarm RedHorseFarm is offline
RedHorseFarm is starting off with a positive reputation.
Better Towing MPG
I've found that my truck pulls way better without using 6th gear. I used to just let it do its thing using all 6, but towing seems a little easier using just 1-5. Also, I noticed a slight mpg increase. With 4 horses on... from 9.3 to 9.8 and with the tack trailer from 8.5 to 9. (thats highway/turnpike towing with cruise on at 68mph, both goosenecks) Just thought I'd share!
Old 04-17-2013, 09:27 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is online now
ATP Pilot is gaining momentum as a positive member of FTE.
I'm guessing 3.73 rear gear?
Old 04-17-2013, 09:50 PM
Yes, you guesses correctly. That's all that was on the lot and I needed the truck right then and there!
Old 05-07-2013, 08:01 PM
arlan in arizona arlan in arizona is offline
arlan in arizona is starting off with a positive reputation.
What weights are we looking at? Is you truck 4x4 Crew Cab and Long Bed?
Old 05-13-2013, 09:42 AM
tolliewolly's Avatar
tolliewolly tolliewolly is offline
tolliewolly is gaining momentum as a positive member of FTE.tolliewolly is gaining momentum as a positive member of FTE.
Is that common go get better gas mileage towing in 5th gars vs 6th?
Old 05-13-2013, 10:36 PM
It's a reg cab long bed 4x4 (FX4)
Ecoboost towing ~9000# enclosed fiveohpatrol 2009 - 2014 F150 27 11-14-2013 07:41 PM
help help help damian arana 1999 to 2016 Super Duty 7 05-29-2009 02:00 PM
Towing heavy with '09 vs '04-'08 F150 windellmc 2009 - 2014 F150 49 12-28-2008 08:08 AM
Fuel Mileage JOE33060 6.4L Power Stroke Diesel 54 09-07-2008 08:30 PM
MY TAKE ON THE EX AFTER 3,600 miles towing scottman70 Excursion - King of SUVs 10 04-17-2007 01:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
