Transmission or Torque Converter or ??? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 04-17-2013, 03:04 PM
ptmares ptmares is offline
ptmares is starting off with a positive reputation.
2007 Expedition with 109k. While driving at a constant speed between 35-55 mph, I get a shuddering like sensation through the cab of the vehicle. More pronounced while climbing a hill.
The feeling is that of a wash board dirt road or rumble strips on the sides of the road. I get another sensation/noise from being stopped on a slight hill and letting the truck roll backwards while in drive. After the hill roll back, still in drive, press the gas (less than 1000rpm's) slightly while going uphill and its as if something releases. Not a loud sound at all. Still felt through the cab.
All fluids changed, tranny, t-case, rear & front diffs. Plugs changed at 101K, and cop's changed 108k.
Any help greatly appreciated.
Old 04-17-2013, 05:40 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
could be anything, I'd not think transmission first. Could be CVs in the front or rear end, could be the brake rotors out of round and warped. Could be a bad ujoint. I'd check the wheel bearings and other suspension parts too while I was at it before I went pulling a trans.
Rubbing/grinding sensation while turning (2012 Lariat) dh_meyer 2009 - 2014 F150 12 11-04-2015 10:32 AM
AOD Slipping Under Hard Acceleration in All Gears dirt_bag Clutch, Transmission, Differential, Axle & Transfer Case 1 08-05-2015 11:46 AM
Thump thump thump when rolling to a stop Raise 1987 - 1996 F150 & Larger F-Series Trucks 28 01-27-2015 09:02 AM
Thumping Noise from front end (4WD) dutchnichols 1999 to 2016 Super Duty 8 09-26-2014 10:29 PM
Shimmy shifting from reverse to drive jblueguy 1997 - 2003 F150 2 07-07-2013 10:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
