EASIEST, least electronics diesel swap into my 78 ford f-250?
NO sensors, NO ECMs or ECUs, No "modules", NO computers, no hours of playing with a laptop to get it to run right.
Im looking for a VERY BASIC diesel swap. I need it to to have a mountain of torque, endure regular abuse, and be able to idle for hours on end while getting reasonable fule milage.
Im new to diesels, I know they are better MPG and more durable than gas engines.
Can someone please point me in the right direction? Cummins 4 or 6 BT? early powerstroke? what should I look for in a naeasy, yet dependable swap into my F-250 4x4?
Thanks.
Thanks.
Received 3,099 Likes
on
on
on
Thanks.
Thanks.
The best compromise between ease of installation and power is probably a 7.3 IDI turbo or a first-gen Cummins 12v. Anything newer is going to be a lot more complex, but there would still be no need to mess with a laptop or fuel maps or anything like that.
on
1 Post
I put an '89 Cummins in my truck. No electronics, minimum wiring. I can't vouch for how simple the install is compared to a 7.3 IDI though. 23+ MPG best recorded, a good solid 18 MPG average.
What ever you do, buy a complete donor truck. It will save you hundreds of dollars in parts and hours in trips to NAPA.
Thanks.
Thanks.
Depending on you're ability, and time you want to spend, you could maybe look at a dt360. They are all mechanical, cheap, and a lot stouter than a cummins or international pickup engine.
Smirks90
Connecticut Chapter
04-28-2016 08:32 PM
BL4CKSUNSH1NE69
08-24-2013 01:56 PM
95f2504x4
38
11-17-2011 08:39 PM
