Instructions for removing door panels, 2006 Exp
I got one rear panel off. There's a few additional steps I'll note for anyone doing this in the future.
Pop off the cover around the door handle.
Pop off the cover/small panel that the window switch is in.
Disconnect the window switch from the harness.
Then the torx screws and bottom screws as noted.
Also a screw on the side of the door panel towards the top outside edge.
Then it pops up and out.
The only casualty is one of the tabs on the door handle cover broke off.
I'll be doing the other rear door and one front door, which I expect will have some differences.
AGrayson84
1997-2006 Expedition & Navigator
05-24-2016 09:37 AM
exp2006
07-27-2006 09:19 AM
ErrorS
01-11-2005 10:47 AM
