Dash Lights and reverse lights
Ok so I just got my "new" 1978 Ford F250 supercab and its got some electrical issues.
First off, the reverse lights do not work. I've searched and read about the neutral safety switch going bad, anyone else have any other leads on what the issue could be? Good bulbs and fuse and the wire looks ok but...they don't work at all.
Second, my dash lights are acting weird. Originally I had my turn signal indicators, my bright indicator, my wiper light, my heater control lights, and my brake/seatbelt lights. Strangely none of my other lights worked. Then I found a loose bulb and when I tightened it, 2/3 of the dash lit up, but the right turn signal indicator and far right cluster lights are now dead (including the once working brake warning light). Why is this? I didn't see anything wrong with cluster when I had it out a few days ago... I don't see any other loose bulbs/connections when I look/feel up in there...
Ok I didn't think there was anything else in the reverse light circuit.
As for the cluster, the circuit board has seen better days and so has the back of the cluster (especially the holes for the bulbs). I don't see anything truly wrong with the cluster. That's why the odd lighting is pattern is stumping me...
If that's not the case, you'll need to get out your multimeter. You do have one, right?
I sure do. Hell I never walk away from my toolbox without it! I'd like to just get a different used cluster...any hints at how much I should be looking to spend on one? Better yet, is there a way to bandaid mine to keep it functional? The circuit board on the back of it is intact and functional and carries voltage (the truck had full working dash lights when I got it). I'm lost because after I had my radio replaced (incorrectly at that), the dash lights became fickle...
A lot of people installing radios mistake the 2-pin radio pigtail as power and ground, which is incorrect. The 2 signals in the pigtail are power, and dash lights - the radio ground is through the chassis. "I installed a radio and now my dash lights don't work" is a pretty common theme on this forum for the exact reason I just described.
Ok I got the dash to work. Turns out that a whole bunch of bulbs were falling out because the plastic dash kept crumbling away. So I just soldered in in some wires on the copper contacts on the dash and on the bulb holders and then they worked fine.
The radio is now working correctly after my dad mixed up the constant power lead and the accessory power lead.
Now I get to remove the taillight switch this afternoon...I hope it's just dirty. I don't really want to buy a new one...
POS factory installed composition material cluster backs can TURN TO DUST before your very eyes!
Hard plastic cluster backs introduced in 1981 Econolines, were the service part replacements for the POS cluster backs used 1975/80.
Two types of cluster backs: With or without oil/amp gauges - See post 10.
Funny, i pulled my cluster today and it did indeed turn to dust.
Numberdummy, does the econoline cluster drop right in with the same contacts and such? The cluster in my 91 econoline looks the same as the part from my 77.
I suppose the million dollar question is will a cluster with oil/amp gauges substitute for one without?
1981/91 Econoline / Retrofit: 1975/79 F100/350 / 1975/80 Econoline / 1978/79 Bronco.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 400 = 800-476-9653.
E1PZ-10848-B .. Hard Plastic Cluster Back-Use with Oil/Amp Warning Lamps / Obsolete
1981/86 Econoline / Retrofit: 1975/79 F100/350 / 1975/80 Econoline / 1978/79 Bronco.
CARPENTER NOS OBSOLETE PARTS has 56.
D6TZ-10K843-B .. Printed Circuit Board-Use with Oil/Amp gauges / Obsolete
1976/79 F100/350 / 1976/91 Econoline / 1978/79 Bronco.
D6TZ-10K843-C .. Printed Circuit Board-Use with Oil/Amp Warning Lamps / Obsolete
1976/78 F100/350 & Econoline / 1978 Bronco.
D9TZ-10K843-A .. Printed Circuit Board-Use with Oil/Amp Warning Lamps / Obsolete
1979 F100/350 & Bronco / 1979/86 Econoline.
radical_reabster
07-17-2017 11:21 PM
Troy97Expedition
1997-2006 Expedition & Navigator
02-20-2013 05:32 PM
stephsG37
Electrical Systems/Wiring
06-08-2012 11:44 AM
