Cooling trouble
Cooling trouble
I've an '85 f-250 with the inline 6 engine in it. Temerature guage runs ...randomly high in it at times. I've replaced thermostat, waterpump, and fan clutch (though none really showed signs of wear), the problem remains. When temperature guage is running hot, it doesn't seem that fan clutch is engaging to fully spin the fan. I'm wondering, is it possible I have a bad temp sending unit, if so, is there a way to verify/test? Also, the truck has no fan shroud, so, i'm wondering if all that open air between the radiator and the fan is preventing the fan from engaging or being useful. Thoughts and advice are hugely appreciated, thanks all.
Pcally. i have a 1985 f150 and yes to the shroud , my gauge used to run high untill i replaced the fan/clutch. a shroud is really needed to force air into the radiator to cool,the actual switch that measures heat is located on the rear passenger side of motor(below the manifold) further back towards the firewall.Up where the hose enters the block ,that hookup is for the computer (sends signal) for control management. Hope this helps , TR
"My 85' came with a single core and a guard that crossed the top of the rad." Yup, my '83 did also and it's not really a shroud but a guard like Joe C says. Mine was removed eons ago with no difference in cooling performance.That 'guard' does between none and none whatsoever for the cooling.
Rick_Fury
03-16-2012 07:20 PM
webster
06-05-2006 11:37 AM
