2007 Ranger Rough Idle
The trucks seems to Idle Rough in Park and Drive, Cold or Hot. It mellows out as soon as I give it gas but at stop lights or in park it goes back to a seemingly rough idle.
This is my first Ford Ranger and dont know if its normal. No code or dummy lights.
2007 2WD 4cyl
2007 2WD 4cyl
Welcome to FTE.
When it seems rough at idle, what does the rpm read???? If you switch the AC on, does it idle up, or does the idle get worse????
If the idle speed is low or gets worse with the AC on, the IAC belongs on your suspect list. The Idle Air Control (IAC), is located on the end of the intake air tube that attaches to the throttle body & often acts out & causes mischief. Maybe try removing & cleaning it with a plastic safe spray like CRC QD, or MAF sensor cleaner, keeping the IAC black cap & electrical connector up, so the solvents don't run in & cause mischief with the little air filter under the cap, or run into the solenoid windings & cause insulation problems.
Cleaning may not last, it didn't for me, but was a good trouble shooting step.
Some thoughts for consideration, let us know how your trouble shoot goes.
