Oil in Boost Line
The crankcase vent is pushing a lot of oil up into the CAC/intake. Could just be overfilled, manual says 18qts total, 15 to refill, but some guys have staved off leaks by only running 14 quarts in the pan. Might want to reroute the CCV if you're seeing a ton of oil in to CAC tubes and it's costing you CAC boots.
13.5qt is what I run to
I used to be in the 15qt area Had BellHousing Drip and BedPlate seep
13.5qt and ALL LEAKS ARE GONE DRY as a BONE
However I still have some oil going threw my CAC System what I guess is normal with a Turbo Charger and CCV System I think the Turbo charger when your at High Boost Creates a HIGH Crank Case Vac press
A dirty Air Filter Probably plays into it
MIKESANDS
16
04-16-2006 12:59 AM
edub32
13
07-17-2005 11:35 PM
