302 oil pump drive/distributor engagement - Ford Truck Enthusiasts Forums
Old 04-16-2013, 11:28 AM
Visine Visine is offline
Visine is starting off with a positive reputation.
Can anyone tell me how much of the oil pump drive is supposed to engage the distributor? When I attempt to reseat my distro, it hits the top of the oil pump drive because the oil pump drive is not aligned in the center of the distro housing in the block. I can use a thin screwdriver to put a glob of wheel grease on the drive shaft to more or less center it, but when I slip the distro down on top, it engeges only about 1/4 to 1/2 inch into the distributor. Is that enough or has my oil pump drive shaft disengaged off the oil pump...?
Old 04-16-2013, 12:42 PM
Poison Oil Racing's Avatar
Poison Oil Racing Poison Oil Racing is offline
Poison Oil Racing is starting off with a positive reputation.
that sounds about right.
Old 04-16-2013, 01:39 PM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
Yes , it doesn't bounce up and down . Good as long as the dist. is seating down good so it seals up the top area and you can turn it to time it .
Old 04-17-2013, 01:07 PM
wotan's Avatar
wotan wotan is offline
wotan is starting off with a positive reputation.
It should sit down until the collar on the distro hits the top of the intake.
Push distro in until it hits the pump shaft, and then have someone bump the starter -- it will slip down that remaining 1/4" right onto the shaft. Remember -- the dizzy gear will be already engaged with the cam so this won't mess up your timing any. Good luck!
Old 04-17-2013, 11:44 PM
Thanks to all of You!
Jim, Wotan, Poison... just wanted to say thanks for the advice. After I removed the dizzy, I was a little concerned with the lateral play the oil pump drive had in the hole and I was hoping it wasn't because it somehow slipped out of the oil pump and was just hanging loose in the crankcase. I guess there is supposed to be some kind of retainer on it to keep it centered but as long as it seats that 1/4 inch or so into the distributor, I am golden. Thanks again you guys for the advice.
If it ain't one dern thing, it's 5 others mountzionryan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 09-05-2016 08:47 PM
Can't install distributor - oil pump shaft not seated balingwire 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-28-2014 11:29 PM
92 f150 pulling my hair out wont start need help. jmc86 1987 - 1996 F150 & Larger F-Series Trucks 18 10-05-2014 01:27 AM
Tapping into power box of f-150 paintballpro650 1997 - 2003 F150 6 05-25-2010 04:31 PM
distributor won't drop in slammed77 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 9 06-02-2004 11:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
