got a couple of questions
Old 04-16-2013, 04:45 AM
eignub's Avatar
eignub
eignub is offline
the first one is does anyone know how to get the antenna off of a 59 f100? I think i can feel a nut holding it on from the inside, but there is no way to get a wrench in there that is big enough to fit it. going by feel it seems like it is very similar to this design. 1949-1951 Radio Antenna Assembly - Cowl Mount - Ford Only - MAC's Antique Auto Parts
That part is lsited for only up to 51, but thats what it feels like. Does anyone have any info on it, or leads on correct replacements so i can just hack it off and replace it?
Next, I converted to a ac delco 10si (think it was 10, not 12) gm alternator a while back with a makeshift bracket i rigged up. While it works, I would like something more solid. I saw mummert sells an alternator bracket but the site says it is for delco 1 wires. Are the cases similar enough that this bracket will work for me? I tried to find some dimensions online to compare the two, but no luck. here is a picture of what i got right now. (the stacked washers have since been replaced with metal bushings)
Yes, it has been a long time since my last post. But my truck has undergone a lot of work and is getting near road worthy, again, and i am excited.
Old 04-16-2013, 08:44 PM
Walston's Avatar
Walston
Walston is offline
I think the best GM alternator mount is from Classic Auto Air. It came with my HVAC kit, but they likely will sell it separately. Check out the attached link. There is a part 2 as well if you are interested. You will find my original alternator looks very familiar to you.
https://www.ford-trucks.com/forums/7...lternator.html
I am not positive on the antenna but I think the ring on the outside unscrews, I am pretty certain that you don't have to unscrew from the inside, but I could be wrong.
Old 04-16-2013, 11:21 PM
eignub's Avatar
eignub
eignub is offline
oh man, your set up before looks just like mine. did you follow the guide on the old ranch wagon site too? i didnt see the brackets for sale separatly, but i'm gonna shoot them an email or maybe call them in the morning and see what they say. it looks like a nice kit.
Old 04-17-2013, 05:39 AM
Walston's Avatar
Walston
Walston is offline
Yes I did.
Old 04-17-2013, 09:28 AM
jamhh's Avatar
jamhh
jamhh is offline
What is the benefit to replacing a generator with an alternator?
Old 04-17-2013, 08:08 PM
Walston's Avatar
Walston
Walston is offline
The voltage from an alternator is constant. The voltage from a generator is RPM dependent. So the lights dim when you come to a stop with a generator and with an alternator they do not. Just one exampe. Essentially the quality of the electricity from an alternator is superior.
seth.pat
08-10-2014 07:20 AM
seth.pat
08-09-2014 12:42 PM
John & Old Ford
12-07-2012 10:11 AM
61fordf25
15
11-27-2010 10:17 PM
bailegb
03-19-2010 08:52 AM
Quick Reply: got a couple of questions
