58 custom cab
Old 04-17-2013, 09:43 PM
Custom66Cab's Avatar
Custom66Cab
Custom66Cab is offline
58 custom cab
I'm having a issue with my truck you guys are the gurus so ill ask y'all 1st. Here goes the truck starts and runs fine but when I go to turn it off and pull the key it stays running . Even with the key out what's he deal with that. Any help is greatly greatly appreciated ..
Old 04-18-2013, 11:23 AM
FJones8668's Avatar
FJones8668
FJones8668 is offline
Ignition switch could be bad, someone could have wired the coil wrong so that something is back feeding power to it with the key off. How do you shut the pickup down? That would help diagnose your problem (maybe). If there was constant power to the coil I would assume it would burn out but if you are shutting the truck down by removing power to the coil it wouldn't be. I would get a test light and go to town under the hood. If you don't have one they are $2 from harbor freight. Do a google search for a wiring diagram, I know I have posted them on here before.
Let us know what you figure out!
BTFordGuy302
36
06-04-2015 01:27 PM
saauvenshine
12-17-2014 12:43 PM
RWhite01
23
06-27-2013 03:22 PM
Spitfire44
18
02-19-2013 09:50 PM
rbwood
29
03-19-2010 05:41 PM
Quick Reply: 58 custom cab
