1959 Door Lock Retainer Clip? - Ford Truck Enthusiasts Forums
Old 04-15-2013, 09:45 PM
Stevie Nash's Avatar
Stevie Nash Stevie Nash is offline
Stevie Nash is starting off with a positive reputation.
Well I bought some door locks from LMC Truck and I need to install them. When I bought the truck it had none, so I don't have the knowledge from taking them off.
So... I can't figure out if I have the clip flipped or not. With the new rubber on the outside its hard enough to push the lock in far enough to get the clip to slip on. Also, I have no idea of how the lock will connect to the door latch. Doesn't appear to be a part in the LMC Truck catalog.
Anyone have any pics of an installed clip, or any tricks to the process?
Old 04-16-2013, 09:07 AM
FJones8668 FJones8668 is offline
FJones8668 is starting off with a positive reputation.
The part that goes between the actual lock and the door mechanism is not included as you say and I have yet to find anyone that sells them. I had to go to a pull and save to get that part.
Old 04-16-2013, 11:52 AM
So now that I know the positioning of the clip, is it supposed to go through the slit in the door jam, or do I come at it from inside the door?
Old 04-16-2013, 04:01 PM
through the slit in the door jam underneath the door rubber moulding
Old 04-16-2013, 09:39 PM
That seemed like it was made for the clip. Thanks for all your help!
Door Clips? Riskit 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-14-2016 09:18 AM
1966 f100 door locks Adam Cleveland 1961 - 1966 F-100 & Larger F-Series Trucks 32 07-27-2015 06:02 PM
Keyed door lock cylinders mnkeeking 1967 - 1972 F-100 & Larger F-Series Trucks 15 11-26-2014 12:28 PM
Trouble replacing door locks Aaron Mitcham 1997 - 2003 F150 3 09-10-2013 03:06 PM
Need New Retaining Clip for Lift Gate Lock Cylinder AndrewWV Excursion - King of SUVs 8 11-05-2011 01:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
