Stop Safely Now! - Ford Truck Enthusiasts Forums
Stop Safely Now!
Old 04-15-2013, 08:57 PM
AvoTow's Avatar
AvoTow AvoTow is offline
AvoTow is starting off with a positive reputation.
Stop Safely Now!
I have a 2012 F250 with 32000+ miles and absolutely no problems. I left this morning with a little over a quarter tank of diesel to check on a crew about 20mi away. I came back to the home ranch and stopped by our diesel tank to fill up.
I put in 18.8 gallons of diesel with no problems, although I did top off the tank. I drive about 200 feet and I receive a red error message that and some angry beeps. The error read Stop Safely Now! I pull slightly off the road and the truck immediately dies. I remove the key and then try to restart and get the same error message. Call the dealership and they tell me to wait 15min and try again, if it still doesnt turn over to get it towed in.
I come back 15min later and the truck still gives me the error message. I call AAA and they send out a tow truck. When the tow gets to the ranch, the truck starts fine. I'm a little embarrassed and explain what happened. He says that air probably got in the fuel line and the computer killed the truck. I still have a check engine light on so I head to the dealership to get it checked out. When I get there they tell me that theyre hammered and wouldnt be able to get me in until Thursday. They also say that if it was air in the fuel line that the check engine light would clear itself.
Sure enough about an hour later the check engine light turned itself off. Has anyone else experienced this? I have limited knowledge on diesel engines, is there anything I can do to avoid this in the future? Thanks.
Old 04-15-2013, 09:33 PM
djousma djousma is offline
djousma has a great reputation on FTE.djousma has a great reputation on FTE.djousma has a great reputation on FTE.djousma has a great reputation on FTE.djousma has a great reputation on FTE.
get a code reader and get the codes. even though the light is off, there should still be a stored code. Autozone will read codes for free. Harbor Freight has readers pretty reasonable. I would want to know.
Old 04-15-2013, 09:44 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
not air in the lines..a EGT sensor is the issue. Air in the lines would have made it run rough at best.
You still had fuel.
EGT sensor reads high. So after the truck cooled down you could start it.
Only way to know for sure though is a code reader.
Old 04-15-2013, 10:01 PM
Tim Young's Avatar
Tim Young Tim Young is offline
I'm just Deplorable!
Tim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputationTim Young has a superb reputation
X2 on what senix said.
Old 04-15-2013, 10:16 PM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
Emissions equipment at it's finest!!
Old 04-15-2013, 10:26 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
EGT sensor , I think also . I love them , they make me lots of money ! Hate it for the owners . I have seen many go bad . Design sucks . Also prone to damage from offroad use . I have seen cornstalks ruin them !
Old 04-16-2013, 11:42 AM
AvoTow's Avatar
Interesting, I'll try and pick up a reader today. I take it off road almost daily for work. Nothing extreme, but a lot of dirt, mud, and rocks. I'll keep you guys posted with what I find.
Old 04-16-2013, 12:07 PM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Why could he read the code through Engineering Mode?
It looks like you have a KR. If you hold the left arrow on the steering wheel down while the key is in "off" hold it down, turn key to run (don't start truck) and be patient for a second the screen in the center dash will say engineering mode. Use the down arrow to scroll to the 3rd screen it will show any codes there for free.
Old 04-16-2013, 01:25 PM
darren32's Avatar
darren32 darren32 is offline
darren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputation
Agreed, the stop safely now is usually one of these
Old 04-16-2013, 02:12 PM
AvoTow's Avatar
Well it just happened again. I'm going to check the code right now. The scariest part is the truck dies immediately. I was loading up my trailer and about to haul a tractor down the freeway. This wouldve been extremely hazardous if it didnt happen while I was still on the ranch. No way I can trust this truck until I take it in.
Update: When I try holding down the Left or the Down button before start it just boots straight to the Stop Safely Now error message.
Old 04-16-2013, 02:54 PM
SavageNFS's Avatar
not a WHITE truck
See Darren's picture...I think you need one of those then.
Old 04-16-2013, 04:59 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Another option is an Edge CTS or similar type of display monitor.
They will retrieve any DTC codes through the OBDII port and display them. I used mine several times on my 2006 6.0L to call my service advisor and ask what the code meant. On my 2006 truck, I even used it to clear any codes that were keeping my truck from starting. Haven't had any codes on my 2011, So have not used it on this truck.
Old 04-17-2013, 04:00 PM
AvoTow's Avatar
You guys nailed it! EGT is busted, going to take a day or two to get the part in. Its been brutal driving around the '02 450 flatbed. Cant wait to get my truck back. Thanks again guys!
Old 04-17-2013, 04:03 PM
senix's Avatar
Just a program note...I think on the passenger battery there is a jumper like on the 6.4 that you can use to bypass and start the truck.
Dont know for certain and ...use at your own risk.
Old 04-17-2013, 05:01 PM
JWC 3's Avatar
Quote:
Glad you got it figured out ! I would buy spares , a code reader , the proper wrench and keep them in the truck ! Along with some PB or WD . If you have it long , it will happen again .
Exhaust Filter Overload - Ford Unable to fix the problem S Frank 6.7L Power Stroke Diesel 20 02-14-2017 01:38 PM
Air leak, bad fuel pump, or HPOP? Hotwheelbill 6.0L Power Stroke Diesel 17 10-21-2014 10:42 AM
Intermittent problem Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 73 09-15-2014 11:29 AM
08 F250 6.4 Diesel dies in extreme cold - not a fuel jelling issue - anyone run into this? Ryck 1999 to 2016 Super Duty 7 02-17-2014 06:46 PM
escape 02 p0161 error and od light blinks Brady Miclos Escape & Escape Hybrid 0 07-10-2013 11:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
