is There any diffrence between 96 and 02 7.3 block and crank - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-15-2013, 02:59 PM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
I have a 02 with a rod knocking and 96 engain that floated the valves, Can I use the 96 to fix the 02?
Second what is a 7.3 block and crank worth?
Old 04-15-2013, 03:03 PM
jkidd_39's Avatar
jkidd_39 jkidd_39 is offline
jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.
You can get a set of rods for reasonable. I would recommend getting new forged rods. And there is only a difference in the front covers.. but for the life of me I cannot remember what specifically that it.
I believe I sold a sleeved block/crank/cam that was ready for a hone for $500.
Old 04-15-2013, 03:04 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
The blocks and crankshafts are different between those years.
Here are a couple of files that explain the differences.
Old 04-15-2013, 03:09 PM
jkidd_39's Avatar
Well then.. guess i'm the jack@ss.. thanks for the info greg
Old 04-15-2013, 03:10 PM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
Good stuff greg...
Thanks for posting
Old 04-15-2013, 03:15 PM
Quote:
No biggie. It looks like a minor difference. I suppose the '96 crank will work in a newer block but the newer crank may not fit the older block. So, I guess if you keep the block and crank together then the OP will be golden.
The lifter guide style is different as well. It says the newer style crankshafts are stronger so I suppose they would be more desired.
Old 04-15-2013, 03:23 PM
I remember reading something about head gasket changes through years as well. I will try and find that page...
Here it is. The newer style F-250/450 gaskets will fit the older blocks so that works out. There is a thinner F-650/750 gasket that creates a higher compression ratio. This is a good way to identify a 650/750 engine at a salvage yard since the corner of the gasket will be visible (also there should be a fuel pump in the valley of the engine).
Old 04-15-2013, 07:29 PM
stinson 108-1's Avatar
stinson 108-1 stinson 108-1 is offline
stinson 108-1
stinson 108-1 has a very good reputation on FTE.stinson 108-1 has a very good reputation on FTE.stinson 108-1 has a very good reputation on FTE.
I've wondered what drove the fuel pump on the pre 99 power strokes, was it a lobe on the cam shaft? I had a 95 and remember the fuel pump being in the valley. If so the cam would be different.
Old 04-15-2013, 07:36 PM
Quote:
Correct. It has a cam lobe and the valve timing is different on the F-650/750 trucks.
Old 04-15-2013, 08:21 PM
stinson 108-1
Thanks Greg, As I said, thats something I wondered about. Didn't Know about the valve timing either.
Old 04-15-2013, 08:56 PM
Thanks, If the crank will bolt up to flexplate it still might work. How is the fuel pump hole in the vally pluged on the newer trucks.
Old 04-15-2013, 09:14 PM
BlueScab's Avatar
BlueScab BlueScab is offline
BlueScab is gaining momentum as a positive member of FTE.
Quote:
Freeze plug
02 7.3 in a 96 f250 crew gasser? DanielT28 1994.5 - 1997 7.3L Power Stroke Diesel 19 07-29-2014 09:15 PM
2001 to 96 7.3 swap Nsherrod 1987 - 1996 F150 & Larger F-Series Trucks 0 11-23-2013 05:38 AM
2002 7.3L cranks but wont start. HELP! r_paetzold 1999 - 2003 7.3L Power Stroke Diesel 10 02-08-2013 03:53 AM
02 7.3 running bad alexisvfd 1999 - 2003 7.3L Power Stroke Diesel 17 11-17-2011 10:02 AM
Motor Identification joeyd61 1999 - 2003 7.3L Power Stroke Diesel 4 02-17-2011 07:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
