302 Oil pump drive shaft aligned with distributor - Ford Truck Enthusiasts Forums
Old 04-15-2013, 02:18 PM
Visine Visine is offline
Visine is starting off with a positive reputation.
I am restoring a 73 F100 and pulled the distributor out of the 302. Can anyone tell me how high up the oil pump drive shaft is supposed to ride in the distributor housing in the block? As I attempted to reinstall, the distributor only seated to the point where it is about 1/4 inch too high. The bottom of the dist. housing is making contact with the top of the oil pump drive which is against the side of the housing in the block. I can move the oil pump drive around in the block housing and "stick" it where it needs to be with a glob of wheel grease but the distributor housing will only engage the oil pump drive about that same 1/4 inch. I was afraid since the drive shaft is moving around in the block, perhaps it came disengaged from the oil pump when I removed the distributor?
Old 04-23-2013, 09:41 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Thread moved to the Small Block V8 forum.
Old 04-23-2013, 09:50 PM
7636074460 7636074460 is offline
7636074460 is gaining momentum as a positive member of FTE.
mine does this, if you turn your crank by hand the distributor should fall in, if not there might be a problem. if it does fall in you will just have to take your time with it where you want it to fall in at.
Old 04-24-2013, 09:16 AM
baddad457 baddad457 is online now
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Take a 1/4" drive, 5/16" deep socket and a long extension, tape the two together (to insure the socket stays put while it's in the engine block. Stick it down into the hole and rotate the driveshaft slightly, then retry stabbing the distributor. The shaft fits about a half inch into the oil pump socket, ditto for the distributor shaft.You're not the first to have this problem, it takes time and patience to get it seated again sometimes.
Old 04-30-2013, 12:54 PM
daveengelson daveengelson is online now
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Wonder if the oil pump rod is aligned; may be able to do so thru suggestions by members; otherwise, hate to think of the labor intensive alternative. If have not already done so, suggest buying an an oil pump primer, reduces the possibility of damaging engine and comes in handy for oil changes, setting rotor location, etc., and cost around $15.
TFI to DSII distributor shaft lenght oip pump annaleigh 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 04-23-2015 04:14 PM
351W with 1/4 inch Distributor shaft?? rocfire Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 06-08-2014 02:26 PM
1986 351 W 4wd-oil pump eriklane 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-22-2013 08:32 PM
223 oil pump and distributor pcmenten Ford Inline Six, 200, 250, 4.9L / 300 0 08-30-2009 11:37 PM
oil pump rod won't drop down? imlowr2 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 07-16-2004 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
