E4OD poo'd (project ZF swap)
#46
To add on to the ignorance... Ive got a few questions for Mark as well...or others.
Will any zf trans from A 7.3 or even 6.9 bolt right up?
I am looking around for you too and have seen a few taken off of 93 IDI's
Does it have to be a manual trans from a diesel to work? I saw a ZF 5 spd advertised that it came off of a 460, but the guy mentioned "will only fit 460"
Also do you need to have transfer case and all? I recall that a diff PCM or ECM is needed?
The 93 trans setup he has listed as barter... usually means they are willing to go cheap. lol
#47
He is right. It will only fit a 460.
#48
If the filter has enough junk in it to affect the trans, you need a rebuild. The only time a filter will plug is when the trans has died. A flush and fill wouldn't clean out the filter, anyway. People talk about backflushing, but it is impossible to backflush a transmission. It can't be done.
#50
#51
IIRC the romp on startup can be eliminated by leaving the Auto harness in place and leaving the TRS on the truck, in either the P or N positions. It isn't a perfect solution, but it will work.
As for the ZF fitment, ANY ZF5 from a diesel (PSD, 7.3 IDI, 6.8 IDI) will work. It just can't be a transmission from a gas truck as they use a different bell housing bolt pattern.
#54
The tailshaft on the 4x2 transmission is different, however (supposedly) the F-Super Duty (or at least some of them) were offered with a tailshaft-mounted emergency brake. If you find one of those they are the same as the 4x4 transmission (or so I am told).
#55
Knew it was something like that Nate, couldnt remember the exact details.
Haha. Depends on what it's worth to you. Right now I have to get something out of it because I've gone into debt getting all the swap parts together .
I'm hoping it has a nice TC when I pull it. Supposedly it was rebuilt about 40k ago.
#56
Well Nate and Alex have both sent me promising leads. Alex's is in Illinois though. Nate sent me an add this morning for a SD OBS for a reasonable price if it runs and shifts. My brother needs a motor for his SD, so I might be able to swing a good deal. I have to break this all to the wife tonight, but a donor truck would obviously be the best route to go if she doesn't blow a gasket over the price.
#57
