Fan Shrouds
Fan Shrouds
I have a 94 F150 that I am swapping the motor out to a 351 from a 95 F250. I diudn't think to get the fan shroud from the donor truck and there are options. I have the 2 row radiator. Is that the heavy duty cooling or standard? Can I use the Standard cooling shroud on the HD cooling or visa versa?
Removing the mystery of shroud...
The heavy duty radiators are nominally ~2" thick while the standard units are only about 1". Remember, that is core thickness not tank thickness. Many radiators with 1" core will have the deeper/thicker tanks. Also note that the fan shroud for a 1" core radiator will be deeper [front to back] and vary a bit in how it mounts so if you swap in a 2" (read better cooling) unit not only will the shroud be too deep/long it also will not mount without modifications.
There is virtually no downside to converting to the higher capacity radiator for ANY application on these trucks. I would highly recommend the upgrade to anyone; if not now certainly upon replacement of a leaking or plugged radiator. Locate you shroud at your leisure so you will be ready when the time comes to replace your radiator!
dn.
dn.
MIKEDEL
06-24-2005 09:32 AM
