2001 Ford
2001 Ford
It's an F-350 4X4 5 spd V-10.
My fuel pump gave up the ghost so I had my neighbor pull the tank for me and get out the old fuel pump readying for a replacement.
Here's the problem, When he took the top of the tank lid off he cut the fuel lines at the connection, then when he realized he screwed up he completey threw the connection away... OK, I screwed up letting someone else do it!
Now I have the new fuel pump in, I bought a Haynes manual to help identify the wires that go together. It doesn't show the fuel tank gauge wires nor the Fuel pump wires. I've done a search here and other places on the web. It's like they want to keep it secret? lol
Would anyone have the wiring diagram for the fuel pump and Gauge sender wiring? I'd be happy to buy it from someone. None of the wires inside that tank compared to the wires outside of the tank match.
Thanks in advance all. I appreciate any help or advise. Ron
I appologize, I didn't make that very clear, my mistake.
He actually cut both the lines in the tank plus the wires on both sides.
Yes, it does have the Diagrams, but the tank area isn't very clear. It doesn't show if the Yellow/White wire goes to the sender or the pump itself.
Thank you Handifletch, I'll check the link out.
Does the Haynes manual you bought have the wiring scamatic in the back?
try this link fuel pump wiring diagram - Ford F150 Forum
