Rough Idle When Hot, Shutdown and Won't Crank
My truck shut off yesterday after idling really rough. I thought fuel filters, changed them (filling them before putting them on) and it finally started after a good bit of spinning and waiting. Drove it around on the job site and it did the same thing. Next thought, CPS. Changed that and it cranked immediately, but the engine was cool. Ran it till the engine got hot, idled rough, shutdown, and wouldn't crank till it cooled some. Checked the engine oil for fuel; none; assume o-rings are good.
Is it possible that I need to replace the IPR?
Thanks
Thanks
Please forgive my ignorance. There is a lot I don't know about these trucks.
I pulled the IPR and the o-rings looked fine, but I replaced them with the ones from Riff Raff Diesel. The job was easy because I have an e-fuel system and so far the truck has been cranking and running fine. Somehow I broke the top off my injection pressure sensor and had to spend the money I saved on the IPR to replace that.
So, thanks to everyone for your help.
