1949 Ford cowl vent
1949 Ford cowl vent
Well boys, I've worked on a lot of vehicles, was Ford certified at one time, along with Chrysler, and even worked at a Mercedes shop, but this cowl vent has me pissed.
I see no earthly way that thing was installed in one piece. The handle, along with the cross rod, are rivetted together. This does not allow enough room to pivot the assembly back far enough to worm it from the cowl opening, the handle smacks the firewall. Furthermore, if you try to open the vent assy., the geometry is even worse, and you cannot even begin to rotate the assembly.
I think I see why so man y have just welded them up. I think it was rivetted together after installation at the factory.
I find that if you take the bolt out that has the spring behind it (inside the cab) and you put the drivers side in first, it can be installed readily. I remove the lid first.
Sorry for not replying folks, got drawn away with other ventures.
You all were absolutely right. After taking the bolt that adjusts the mechanism out, the assembly was pretty easy to worm out. Got the new seal in relatively easy, but have had the "cowl vent cover sticks up" problem. Thought perhaps the summer heat would allow the rubber to settle, but no. Leaks a little to boot.
I know that this issue was raised in another thread. Will have to look it up.
jvmcc
06-11-2016 06:22 PM
