Will this work?
They have different axle numbers and names because they are different. Different total width, shaft size, carrier size, pinion shaft size and depth, c clip or not. Lots of variations.
It would help if we knew what you have in your bronco now for and axle. The 350 is probably a dana 60. Not to mention the gear ratios are probably different.
The bronco has a 44 and the 350 is a 60 with 4:10's I have the matching rear rear I plan to use I was just thinking it may be better for me to swap everything from the 60 to the 44 rather then trying to make the 60 fit the coil spring set up in the bronco. Basically I just put a built motor in the bronco and want to run bigger tires therefore I need stronger axles but I'm on a tight budget and have the rears laying around so I was hoping for an easy way to make it work
1976 ranger
1966 - 1977 Early Broncos
08-15-2007 12:00 AM
80Bronco94
08-20-2004 11:51 PM
blackrhino
12-14-2003 11:43 AM
