59 F100 turn signals - Ford Truck Enthusiasts Forums
Old 04-14-2013, 09:52 AM
leewiffen leewiffen is offline
leewiffen is starting off with a positive reputation.
Any auto electricians out there?
On the side light / indicator lights on the front, with the dual filament bulb, is one wire going in for the side light and the other for the turn signal with the ground being provided from the lamp housing which is attached to the main front grille ?
Old 04-14-2013, 01:11 PM
F-100CustomCabTBC's Avatar
F-100CustomCabTBC F-100CustomCabTBC is offline
F-100CustomCabTBC is starting off with a positive reputation.
I believe that is correct. I think when I was wiring mine up I held the housing on the Neg. terminal of a 9V battery and hooked each wire up to the positive terminal just to make sure each filliment lit up which they did.
Old 04-14-2013, 01:29 PM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
Correct. Wiring Diagram shows yellow is lights from dash switch, blue is pass and green is drivers turn signals.
Old 04-14-2013, 02:11 PM
Some time ago I cut the power wire which was connected the side light to the new headlights I fitted leaving the indicators working. It has been fine for a while . Recently the indicators stopped working. I changed the flasher unit, checked all the bulbs...no joy. I fiddled with the fuses on the light switch and they started to work, but intermittently and strangely the electric fuel pump that is fitted was heard to be clicking. I thought bad ground, but despite connecting one of the front bulb holders direct to ground of the battery, taking the light switch out and cleaning it all up, the turn signals are still intermittent when I connect them to the white wire that is part of the dual plug up by the radiator.....any clues?
Old 04-14-2013, 02:31 PM
Damifiknow's Avatar
Quote:
White/blue tracer is pass to directional switch
Green/white tracer is drivers to directional switch
black/yellow tracer is from light switch on dash for parking lights.
Hope this helps.
I dont know about how electric fuel pump is wired. Sounds like you need to invest in a wiring diagram. Ebay laminated is clear and only about 20 bucks.
www.classiccarwiring.com or 917 861 9131
Old 04-15-2013, 01:08 PM
Well this where I'm at.....I have cleaned and grounded all the individual fittings, front and rear. Renewed all the bulbs. When I put on the ignition and use the turn signal on the steering column the lamps light, but do not blink, but, if I fiddle with the indicator stalk they will intermittently blink whilst making the aftermarket electric fuel pump operate !! This pump has a feed coming directly from the ignition switch, through a ten amp fuse and fuse holder and grounded direct to the chassis
Old 04-15-2013, 05:09 PM
Damifiknow's Avatar
how many threads are going to start about this?
Old 04-15-2013, 09:19 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
That is why it is referred to as AC/DC theory!
Short in turn signal? wrdabney 1987 - 1996 F150 & Larger F-Series Trucks 37 07-18-2016 02:53 PM
marker,turn signal lights marty277 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-17-2016 05:56 PM
turn signals mr56effie 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-08-2014 10:29 PM
turn signal problems boo-yaa138 1967 - 1972 F-100 & Larger F-Series Trucks 16 03-10-2014 01:48 PM
My truck had stroke or so it seems Scoop531 1973 - 1979 F-100 & Larger F-Series Trucks 14 01-31-2014 09:12 PM
Tags
side lights, turn signal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
