98 Explorer 5.0 Engine Spec Sheet - Ford Truck Enthusiasts Forums
Old 04-14-2013, 01:01 AM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
I thought this would be handy for some of you... It comes straight from Ford. I posted this in the Explorer thread as well.Should be good information for most of the 5.0L engine applications.
<iframe src="https://skydrive.live.com/embed?cid=04BEF4AD9FF0951C&resid=4BEF4AD9FF0951C%2 1557&authkey=AAgVmzHWDeGjqsQ" width="98" height="120" frameborder="0" scrolling="no"></iframe>
Old 04-14-2013, 02:49 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
Yes, there is nothing unique in the Explorer shortblock it's the same as any other truck 5.0 built after 1994 so most of those specs apply, the heads and intake is where this motor differs from the norm.
Old 04-22-2013, 08:20 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
They changed the pistons sometime around 96-97, I tore down a 97 motor a year or so ago and the pistons were noticeably different in the skirt than those used previously.
Putting her to work- a little snow plowing Ford Fx4 6.7L Power Stroke Diesel 12 01-25-2015 10:07 PM
Aarons obs seat fix madMatador78 1994.5 - 1997 7.3L Power Stroke Diesel 23 12-29-2014 04:22 PM
Sagging in the middle? sseebart 1961 - 1966 F-100 & Larger F-Series Trucks 6 07-25-2014 09:12 AM
project short stroke quesey 1994.5 - 1997 7.3L Power Stroke Diesel 11 07-04-2014 11:04 PM
U-Joint Install Trouble 9mpg Excursion - King of SUVs 21 09-23-2011 06:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
