Rear end noise
Old 04-13-2013, 09:02 PM
CRF1966's Avatar
CRF1966
CRF1966 is offline
Rear end noise
My wife has a 2010 F150 Supercrew with 77000 miles and I have noticed a Howling noise coming from the rear end when the truck is coasting at hwy speeds, going down hills or when you let off the gas and start coasting. Has anyone else had this issues. I thought it was the tires at first because they were due for replacement, got new tires noise still there. Any thoughts on this?
Old 04-16-2013, 12:33 PM
Skoiv's Avatar
Skoiv
Skoiv is offline
My 2000 Expedition did the same exact thing at about the same mileage. It howled while coasting but not under power. It turned out to be the pinion seal and bearings in the rear end. I spent $750 bucks to fix it it. After the fix I went for 130K trouble free miles with the new seal and new bearings.
Old 04-17-2013, 09:01 AM
SnakeOiler's Avatar
SnakeOiler
SnakeOiler is offline
Had the same problem on a 05 150. Solution was pinion seal and bearings. $900 in 09.
Kurts12F150STX
2009 - 2014 F150
01-28-2018 12:58 PM
jdmcivic23
09-29-2013 02:37 PM
olecarman
2004 - 2008 F150
08-25-2012 01:16 PM
indychuck
1997-2006 Expedition & Navigator
05-03-2012 02:32 PM
cfave
2004 - 2008 F150
11-06-2007 02:51 PM
Quick Reply: Rear end noise
