Rear end noise - Ford Truck Enthusiasts Forums
Rear end noise
Old 04-13-2013, 10:02 PM
CRF1966's Avatar
CRF1966 CRF1966 is offline
CRF1966 is starting off with a positive reputation.
Rear end noise
My wife has a 2010 F150 Supercrew with 77000 miles and I have noticed a Howling noise coming from the rear end when the truck is coasting at hwy speeds, going down hills or when you let off the gas and start coasting. Has anyone else had this issues. I thought it was the tires at first because they were due for replacement, got new tires noise still there. Any thoughts on this?
Old 04-16-2013, 01:33 PM
Skoiv's Avatar
Skoiv Skoiv is offline
Skoiv is gaining momentum as a positive member of FTE.
My 2000 Expedition did the same exact thing at about the same mileage. It howled while coasting but not under power. It turned out to be the pinion seal and bearings in the rear end. I spent $750 bucks to fix it it. After the fix I went for 130K trouble free miles with the new seal and new bearings.
Old 04-17-2013, 10:01 AM
SnakeOiler SnakeOiler is offline
SnakeOiler is starting off with a positive reputation.
Had the same problem on a 05 150. Solution was pinion seal and bearings. $900 in 09.
2000 F250 7.3 Diesel Rear end noise tmyers921 1999 to 2016 Super Duty 6 06-14-2016 02:14 PM
A new noise? Totally Tuna Excursion - King of SUVs 4 08-08-2015 10:58 PM
New Noise? Totally Tuna 6.0L Power Stroke Diesel 1 08-08-2015 01:13 AM
Grinding Noise Front Driver's Side When Decelerating PeteB4 1999 to 2016 Super Duty 14 07-03-2013 01:12 PM
Rear end hum Joe Finn 1997 - 2003 F150 9 12-12-2006 07:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
