Will this wheel work on a 2013 expedition? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 04-13-2013, 09:23 PM
johnkn johnkn is offline
johnkn is gaining momentum as a positive member of FTE.
Anyone know if the offset is correct on a 2009 f150 Platinum wheel to fit the Expedition. The car I'm getting has 18s and I plan on installing a set of chrome 20" ford wheels with one size taller michelins, 275x60x20 vs the stock size 275x55x20 The 60's are virtually the same width and section, but almost an inch taller and should ride a bit better with the extra sidewall as well as filling up the wheel well a bit
California Chrome Wheel Inc. - Chrome Wheels for Jaguar, Land Rover, Lexus, Mercedes, and more
Anyone know what the expedition 20" offset is? I believe it's stamped on the back of the wheel. I believe all the expedition and f150 20x 8.5" wide wheels have a 44mm offset but not certain
Old 04-13-2013, 09:53 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Yes the wheels will fit fine ( same offset F150 = Expedition 2004 up)
You will have to have the computer reflashed to adjust for the difference in tire height though.
Matt
Old 04-14-2013, 11:03 AM
I really ha e to ref lash for a .9" change in tire diameter? Can the dealer do that?
Old 04-15-2013, 10:19 AM
RI-Matt's Avatar
Check out this link. It will show the variations in tire sizes in relation to actual speed.
Tire Size Calculator - Discount Tire Direct
According to the calculations your speedo would be of 2-3 miles per hour. I think the problem is the computer is expecting to see x # of revolutions per mile when it does its calculations for Advance Trac/ RSC and yaw control etc......
I would think a dealership could reflash it.
Matt
Wheel Specs nobody1 2004 - 2008 F150 4 12-31-2013 09:52 AM
2007 F150 Factory Wheel Specs nobody1 Brakes, Steering, Suspension, Tires, & Wheels 0 12-30-2013 11:25 AM
Brand New Chrome F150/Expedition Lariat Wheels johnkn Ford Truck Parts for Sale 0 06-02-2013 09:49 PM
Will these wheels work? nut1605 1999 to 2016 Super Duty 5 05-03-2013 07:22 PM
Ordered New Wheels for 2013 Expedition johnkn 2007 - 2014 Expedition & Navigator 6 04-27-2013 12:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
