Black fuel filters
Josh
Thanks for replying! I've never run biodiesel to the best of my knowledge. The only stations that I've used are right around my house. I normally buy only from a little Valero station here (Ramona CA), which does a pretty high volume, but for convenience have purchased somewhere between 20 and 40 gallons from a "star" station around the corner in the last few weeks. Not that it matters, but it's a large, very nice station which seems to do a pretty good volume. My guess is this is the source of the bad fuel, I don't know where else it could have come from. None of my other fuel filter changes have looked anything like this, in fact they didn't look dirty at all. The only fuel filter that I've seen look like this was the lower filter when I first bought this several years ago, and I am pretty sure that it had never been changed . The jar in the photo is everything from draining the water trap, and I see nothing in it, not even water FWIW. So the question is, do I assume a fuel filter change will do it, change them and watch my fuel pressure, or do I assume I now have some microbes growing in my tank which are going do do in $80.00 worth of filters on a semi-regular basis?
If you are paying $80 for the fuel filters you need to buy from a better place. Also check on the below links for oil filters.
For instance:
Riffraff Diesel: 6.0L Fuel Filter Set
[PFF-4616] - Racor PFF4616- Ford 6.0 Liter Turbo Diesel Fuel/Water Seperator Filters: Pick Up & Excursion-REPLACES FD-4604/FD-4616 - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
For instance:
Also, I've been thinking since my last post... who knows where they got dirty! Just because it's now reached a problem level doesn't mean that it was at the station I've used a couple of times lately. It could be my regular station, and it could be anywhere. In the 7000 miles on these filters I've done 3000 to 4000 miles on the road through 7 states. I try to find the high volume stations, but when you're on the road, who really knows. I think at this point I will put in new filters, dump in some Stanadyne, including in the upper fuel bowl, do the blue spring mod, and get the fuel pressure hookup done for my DASHBOSS. Then watch and see I guess...
For instance:
For instance:
Thank you, thank you!!!! The only place I've found around here for motorcraft OEM filters is Wallyworld, whose out of them 3/4 of the time, and the local stealership, who charges me $80.00. I'll be calling Riffraff on Monday. I really appreciate your help.
I don't know where exactly you are at, but if you have an International Truck dealer in your area you can buy part# 1847170C94. It is the exact same thing.
You can walk in off the street to their parts counter and they'll sell to you.
Dealers - Find a Dealer | International Trucks
Actually, they are absolutely Motorcraft purchased only from the Ford Dealership. No other brand has ever been in this engine before. I purchased them and put them in myself each time. I've been hovering around here way too long not to know better. Thanks for bringing that up though, that's always an important point. Mike
