Reference Thread: CAB/BED Mounting Hole Spacing - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Old 04-13-2013, 05:51 AM
Greywolf's Avatar
Greywolf Greywolf is offline
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
(applies to all projects)
I've been meaning to get out and actually measure the frame rail spacing, and center to center cab and bed mount spacing for the 1989 shorty Ranger frame I have out front. I'll post that info here once I get the pics or whatever
The usefulness of it is in knowing how far apart things have to be to swap different cabs around - sometimes cabs you wouldn't believe... to chassis that are just plain better in some way
* somewhere on here I remember reading that somebody had dropped a 40 or 50 F100 cab on a Courier chassis
Most cabs will have three pairs of mount bolts,
2 at the front near the radiator support
2 in the cab floor by the firewall
2 behind the seats at the cab floor rear
*Crew Cabs, Bronco's, Excursions - etc... will be unique
Beds may have as few as 6, but usually have 8,
equally spaced from front to back
**ON 1/4 Ton Ranger Frames, the firewall cab mount is LOWER than the rest of the mounts
For a normal truck though, I would short-hand label the bolts/mounts as:
CLF (cab left front)
CLC (cab left center)
CRR (cab right rear)
BL-1 (bed, left, ONE)
~ and so on, because we number stuff from front to back, right?
Could be 3 pairs, could be 4
BL3, BL4, maybe even BL5 for a long enough bed...
Old 04-13-2013, 03:46 PM
Greywolf's Avatar
The 1989 Ranger frame does have a six bolt BED MOUNT set, but it is patterned as if it was an eight bolt with the row in front of the rear axle missing
2) The bed mount bolts go DIRECTLY THROUGH THE TOP OF THE FRAME RAILS.
3) The CAB MOUNTS are on saddles - OUTSIDE THE FRAMERAILS
Hmm...
It makes me wonder if the frame rails could be straight pieces of channel if it wasn't for the cab floor...
It also makes me wonder about 4 inch wider frames for strength, but well hidden.
Q: Does FORD own MAZDA?
Yet another build thread- with a twist Ford_Six 1967 - 1972 F-100 & Larger F-Series Trucks 75 01-17-2017 10:21 PM
standard cab and crew cab front mount location spacing Earnie Rosenow 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-10-2016 12:40 PM
Could use the help of someone with a tape measure and a creeper please. rk-rex 1961 - 1966 F-100 & Larger F-Series Trucks 7 12-31-2015 06:06 PM
51 Bonus Built on Ranger frame NotEnoughTrucks2014 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-06-2014 09:57 AM
long bed vs short bed srrings??? dynamic 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-04-2011 07:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
