2007 Expedition EL EB crank no start
I’m pretty much at a loss as to why my expedition won’t start.
So it cranks but won’t start
i have replaced:
battery
fuel injectors
spark plugs
ignition coils
both cam shaft position sensors
crank shaft position sensor
pcm
things that i do know are:
I have spark
have fuel pressure
injectors are opening
cats aren’t clogged
fuses are good
relays are good
can’t find any broken vac lines
no codes
when it died Wife was going down hill on a high rise bridge and didn’t really noticed it had died until she lost speed and had to pull over but she said it didn’t shake or make any noises
i have replaced:
battery
fuel injectors
spark plugs
ignition coils
pcm
I have spark
have fuel pressure
cats aren’t clogged
fuses are good
relays are good
no codes
makuloco2000
1997-2006 Expedition & Navigator
09-01-2014 12:52 PM
Briancolorado
07-25-2012 12:26 PM
