radiator - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
radiator
Old 04-12-2013, 11:47 AM
okiewelder okiewelder is offline
okiewelder is starting off with a positive reputation.
radiator
Ok l had a rad out of a 79 f150-460 that is a mid mount 4 core. It fit the original core support of mu 62 uni. I just had to cut the top of the crossmember out so it could go down enough. That radiator is not rebuildable so l need to find a new one. I cannt find a replacement locally or online that l can afford but, l see some aluminum 3 and 4 row on ebay. Has anyone used any of these. I am running a mild 460 with electric fans and just want to buy right the first time.
Thanks Steven
Old 04-12-2013, 12:39 PM
37 Ford guy's Avatar
37 Ford guy 37 Ford guy is offline
37 Ford guy has a good reputation on FTE.37 Ford guy has a good reputation on FTE.
Quote:
Thanks Steven
I just bought this one for my '66 but haven't installed it yet. With aluminum you need to make sure your coolant works with aluminum, only use distilled water to dilute and ground it to the body to prevent electrolosis.
This looks nice, appears to be well made and has a lifetime warranty.
Hope that helps a little....
Old 05-09-2013, 09:18 AM
I ordered the four row alum but it was back ordered so l didnt want to report back on it.
Old 06-09-2013, 07:53 PM
Ok, l orded off Ebay from reliable rad. When l made my order they said they had 10 in stock. Then when l paid they emailed me and said it would be a couple of weeks back ordered.
I havent driven my truck since 1988 but l, its closer to being on the road then it has been in years. So l figured a few weeks was no big deal. so l emailed them on friday and they emailed me back saying container was in but wasnt sure if my rad was in the shipment or not.
Just venting l gues. Will update if l get it this week or hear anything back.
Old 07-06-2013, 10:55 PM
Finally got the rad and it is installed in the truck. The brackets were a little different but l made it work. It is about 8 inches shorter then factory 4 row that l had from the 79 ford. I have not put water in it yet l have been messing with the fenders and such. It does look like a descent rad for the money.
Old 07-06-2013, 11:53 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Ok l had a radiator out of a 79 F150-460 that is a mid mount Super Cooling 4 core. It fit the original core support of my 62 uni. I just had to cut the top of the crossmember out so it could go down enough.
That radiator is not rebuildable so l need to find a new one. I cannot find a replacement locally or online that l can afford.
FYI: Same Super Cooling radiator (D3TZ-8005-G): 1973/76 F100/350 360/390 & 1973/79 F100/350 460.
Super Cooling optional 1973/76 F100/350 with 360/390 / Optional on 1973/74 F100/350 460 without A/C / Standard equipment on all 1975/79 F100/350 460.
E350 Radiator & Fan Shroud 460 '94 BYOBoat 1968-2013 Full Size Vans 0 07-23-2015 12:07 AM
radiator help Dave145 1973 - 1979 F-100 & Larger F-Series Trucks 0 07-19-2013 12:55 AM
IDI radiator fit in gas core support kjgibson2 1987 - 1996 F150 & Larger F-Series Trucks 1 10-25-2012 06:22 PM
3 core radiator replacement CJM8515 1987 - 1996 F150 & Larger F-Series Trucks 7 07-26-2010 07:29 PM
Single core radiator with A/C? qquake2k 1987 - 1996 F150 & Larger F-Series Trucks 6 07-21-2010 02:42 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
