Intake manifold replacement - 2001 f150 5.4 - Ford Truck Enthusiasts Forums
Old 04-12-2013, 09:28 AM
dgoebelt dgoebelt is offline
dgoebelt is starting off with a positive reputation.
Hello, I'm replacing my intake manifold due to what appears to be a common coolant leak on the front passenger side. This is my first manifold replacement and a buddy of mine told me I needed to use a gasket sealant, that I could just put the new manifold on. I've searched around and not seen any one else express experience with this specific issue. I got the dorman replacement and I've torn the engine down to the manifold which I'm in the process of taking off now. Is there anything I should replace now that I have access to the top of the engine (plugs were just done)?
Also, does anyone know where I can get new manifold bolts, the old ones look pretty brittle.
My main question though is if I need the sealant cause I really don't want to do this job twice.
Old 04-12-2013, 10:23 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
I think most of the gaskets have a rubber right imbedded in them. I always like to wipe a VERY thin layer of RTV on the gaskets to make them sticky and then install. I think a lot of places install them dry.
Old 04-12-2013, 10:24 PM
steve(ill)'s Avatar
Old 04-13-2013, 09:57 AM
Quote:
Thanks for the tip. I think I am going to use a like coat of rtv as you suggested. My only concern is getting it everywhere when I slide the manifold back in, that or taking so long that it dries and messing up the mating surface.
351M/400M Intake Manifold Swap. . .couple quick ?'s atomicjoe23 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 17 05-08-2014 06:38 PM
Chevy 305 lower intake manifold gasket Frapper General Automotive Discussion 6 04-27-2012 05:44 PM
Forgot to put silicone sealant on new intake manifold water passages. . .big deal??? atomicjoe23 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 08-15-2010 09:13 PM
Intake manifold installation question cart7 3.8 & 4.2L V6 6 11-16-2005 06:52 AM
Stock Intake Manifold Help: '64 F100 292ci Hallmarkreno 1961 - 1966 F-100 & Larger F-Series Trucks 2 02-26-2005 11:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
