How many qts of transmission fluid does a 98 F150 4x4 with 4.2 take - Ford Truck Enthusiasts Forums
Old 04-12-2013, 08:31 AM
AFordMan AFordMan is offline
AFordMan is starting off with a positive reputation.
My gasket on the transmission is leaking. How many qts of fluid do I need to change it and it is a automatic.
Old 04-12-2013, 10:28 AM
shapleigh shapleigh is offline
shapleigh is starting off with a positive reputation.
not sure what transmission you have, but 3.5-6 qts for a simple filter/gasket change, a complete fluid change could be anywhere between 9 and 18 qts depending on the transmission
Old 04-13-2013, 07:10 AM
R Pope R Pope is offline
R Pope is starting off with a positive reputation.
I strongly recommend that you pull the torque converter plug and drain it too, for a full fluid change. The rubber plug in the bellhousing gives access to the plug in the TC. Then a new filter and about 11 quarts of fluid, you are set for many more years.
2008 trans pan upgrade-how many qts of fluid? Money-Pit 6.0L Power Stroke Diesel 3 11-17-2013 06:45 PM
Transmission Fluid Change makthenif 1997 - 2003 F150 3 09-19-2013 06:57 PM
C6 fluid amount. PRIMERED79 SHORT BED 1973 - 1979 F-100 & Larger F-Series Trucks 12 06-27-2013 01:37 PM
Transmission service - '95 F150 5.0 4x4 auto bang4dabuck 1987 - 1996 F150 & Larger F-Series Trucks 4 01-02-2011 01:07 PM
Transmission Fluid Change rocky1074 1999 to 2016 Super Duty 9 08-29-2009 10:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
