1999 f250 V10 surges - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 04-11-2013, 03:03 PM
Slingnsteel Slingnsteel is offline
Slingnsteel is starting off with a positive reputation.
I have owned this truck for 2 years and it is running as good for me as it has ever has at this point. When I accelerate it kinda surges a bit. It's not a smooth acceleration every time though sometimes it does. When I am at 40 mph in overdrive and step on the gas it starts to bump as if units not firing properly. If I take it out of OD it accelerates fine but sometimes surges. Is that normal?
Here is a list of what I have done recently;
Checked fuel pressure, it's 38 at turn the key, 30 idling and around 35 while driving and does not go under 32 any time.
New fuel filter, o2 censors, plugs, coils, two new headers, new egr valve, egr pressure sensor, new egr tube.
At this point I am a bit flustered at what it could be. I am leaving it to the experts to ponder. Any advice would be much appreciated.
SM
Old 04-11-2013, 07:36 PM
I checked for vacuum leaks today. I have a vacuum solenoid in the pic below it does leak so i removed it and capped off the vac hoses with the plug in the second photo. The vac solenoid was replaced last year and never worked. I am not is % sure but I think its supposed to engage the auto hubs and i believe create vac for heater settings. Anyone have any history with this issue and would it cause my bad vac to make my truck run poorly?
SM
Old 04-12-2013, 12:04 AM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Could it be a bad TPS (Throttle Position Sensor)?
Old 04-12-2013, 06:03 PM
Wolfboro's Avatar
Wolfboro Wolfboro is online now
Wolfboro is gaining momentum as a positive member of FTE.
Have you cleaned the MAF (mass air-flow sensor ) lately ?
It is located behind the air-filter housing . Use an MAF cleaner ONLY .
Good luck,
Old 04-12-2013, 06:36 PM
Cleaned MAF 2 days ago. I renoved the O2 sensors this morning and took it for a test drive. It drove much better. I am having a new cat installed ATM, fingers crossed.
SM
Old 04-12-2013, 10:39 PM
changed the cat, runs much better. when in OD at 45-50 it still struggles to jump into a lower gear, it hesitates a bit. less surging wich is good. I have a scanner, i just dont know how to upload info to pc.
SM
Old 04-13-2013, 11:29 AM
Wolfboro's Avatar
Here is the " basic check " with a scanner (it should pass this test) ;Do the following " live data" test with engine hot (normal operating temperature , Closed loop).
1-Fuel Trim (Short TermFuel Trim –STFT & Long Term Fuel Trim –LTFT )
Should be between +10% and - 10%
If so, your engine is OK . Otherwise ( if it is +/- 20 % or so , check injectors ,fuel pump etc. )
(PS. When engine is cold , not all sensors are working ).
2-RPM
Idle RPM 650-800 .
3-Spark Advance (Ignition Timing )
15-25 degree at idle
About 45 degrees at high idle
4- O2 Sensors
B1(bank one-cylinder #1 side )
S1(sensor –before catalytic converter( CC) – upstream of CC )
S2( sensor after catalytic converter(CC) – downstream of CC )
One monitors the engine the other monitors the catalytic converter .
Voltage should be between 0.1 -0.9 Volt ( 0.450 V most efficient )
<o</o
Also ,check if there is any "pending code" and "emission test readiness" lights ( green, yellow , red ) , all of these will give you some clues about the puzzle you are dealing with .
Again this is a very basic test . You may need to search for other live data values for further diagnostic work . You-Tube could be a good source .
Good luck,
<o</o
Old 04-14-2013, 02:36 PM
here is a copy of my live data.
Live Data
O2B2S1(V) 0.050
O2B1S1(V) 0.790
FUELSYS2 N/A
LOAD_PCT(%) 28.6
ETC(F) 192
SHRTFT1(%) -3.9
LONGFT1(%) 6.3
SHRTFT2(%) -1.6
LONGFT2(%) 5.5
RPM(/min) 812
VSS(mph) 0
SPARKADV() 15
IAT(F) 64
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.805
SHRTFTB1S1(%) -4.7
O2B2S1(V) 0.075
SHRTFTB2S1(%) 0.8
OBD OBD1
O2B2S1(V) 0.680
O2B1S1(V) 0.125
FUELSYS2 N/A
LOAD_PCT(%) 28.6
ETC(F) 192
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) 1.6
LONGFT2(%) 5.5
RPM(/min) 818
VSS(mph) 0
SPARKADV() 12
IAT(F) 64
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.710
SHRTFTB1S1(%) -3.1
O2B2S1(V) 0.740
SHRTFTB2S1(%) -3.9
OBD OBD1
O2B2S1(V) 0.055
O2B1S1(V) 0.110
FUELSYS2 N/A
LOAD_PCT(%) 27.5
ETC(F) 192
SHRTFT1(%) -0.8
LONGFT1(%) 5.5
SHRTFT2(%) -0.8
LONGFT2(%) 5.5
RPM(/min) 809
VSS(mph) 0
SPARKADV() 13
IAT(F) 64
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.085
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.240
SHRTFTB2S1(%) -0.8
OBD OBD1
O2B2S1(V) 0.365
O2B1S1(V) 0.080
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(F) 192
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) -3.9
LONGFT2(%) 5.5
RPM(/min) 789
VSS(mph) 0
SPARKADV() 15
IAT(F) 64
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.075
SHRTFTB1S1(%) 0.8
O2B2S1(V) 0.625
SHRTFTB2S1(%) -2.3
OBD OBD1
O2B2S1(V) 0.075
O2B1S1(V) 0.790
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 194
SHRTFT1(%) 1.6
LONGFT1(%) 5.5
SHRTFT2(%) -0.8
LONGFT2(%) 5.5
RPM(/min) 785
VSS(mph) 0
SPARKADV() 14
IAT(F) 64
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.705
SHRTFTB1S1(%) -2.3
O2B2S1(V) 0.100
SHRTFTB2S1(%) 1.6
OBD OBD1
O2B2S1(V) 0.735
O2B1S1(V) 0.780
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 194
SHRTFT1(%) -0.8
LONGFT1(%) 5.5
SHRTFT2(%) 0.8
LONGFT2(%) 5.5
RPM(/min) 799
VSS(mph) 0
SPARKADV() 13
IAT(F) 64
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.800
SHRTFTB1S1(%) 0.0
O2B2S1(V) 0.730
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.145
O2B1S1(V) 0.235
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 194
SHRTFT1(%) 0.8
LONGFT1(%) 5.5
SHRTFT2(%) -3.1
LONGFT2(%) 5.5
RPM(/min) 795
VSS(mph) 0
SPARKADV() 15
IAT(F) 64
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.075
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.690
SHRTFTB2S1(%) -0.8
OBD OBD1
O2B2S1(V) 0.065
O2B1S1(V) 0.790
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) -1.6
LONGFT2(%) 5.5
RPM(/min) 818
VSS(mph) 0
SPARKADV() 15
IAT(F) 64
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.140
SHRTFTB1S1(%) 0.8
O2B2S1(V) 0.070
SHRTFTB2S1(%) 0.8
OBD OBD1
O2B2S1(V) 0.750
O2B1S1(V) 0.085
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 198
SHRTFT1(%) 1.6
LONGFT1(%) 5.5
SHRTFT2(%) -1.6
LONGFT2(%) 5.5
RPM(/min) 790
VSS(mph) 0
SPARKADV() 15
IAT(F) 64
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.075
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.745
SHRTFTB2S1(%) -2.3
OBD OBD1
O2B2S1(V) 0.065
O2B1S1(V) 0.425
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(F) 198
SHRTFT1(%) 1.6
LONGFT1(%) 5.5
SHRTFT2(%) -1.6
LONGFT2(%) 5.5
RPM(/min) 808
VSS(mph) 0
SPARKADV() 14
IAT(F) 64
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.075
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.170
SHRTFTB2S1(%) 2.3
OBD OBD1
O2B2S1(V) 0.720
O2B1S1(V) 0.615
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 198
SHRTFT1(%) 0.8
LONGFT1(%) 5.5
SHRTFT2(%) 0.8
LONGFT2(%) 5.5
RPM(/min) 797
VSS(mph) 0
SPARKADV() 14
IAT(F) 64
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.110
SHRTFTB1S1(%) 3.1
O2B2S1(V) 0.680
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.165
O2B1S1(V) 0.400
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 194
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 817
VSS(mph) 0
SPARKADV() 15
IAT(F) 64
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.110
SHRTFTB1S1(%) 0.0
O2B2S1(V) 0.120
SHRTFTB2S1(%) 0.0
OBD OBD1
O2B2S1(V) 0.550
O2B1S1(V) 0.120
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 194
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) 2.3
LONGFT2(%) 5.5
RPM(/min) 824
VSS(mph) 0
SPARKADV() 14
IAT(F) 64
MAF(lb/min) 1.118
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.800
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.485
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.760
O2B1S1(V) 0.095
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 192
SHRTFT1(%) 1.6
LONGFT1(%) 5.5
SHRTFT2(%) 0.0
LONGFT2(%) 5.5
RPM(/min) 797
VSS(mph) 0
SPARKADV() 13
IAT(F) 64
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.075
SHRTFTB1S1(%) 2.3
O2B2S1(V) 0.555
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.355
O2B1S1(V) 0.200
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(F) 192
SHRTFT1(%) 2.3
LONGFT1(%) 5.5
SHRTFT2(%) -3.1
LONGFT2(%) 5.5
RPM(/min) 789
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.790
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.715
SHRTFTB2S1(%) -1.6
OBD OBD1
O2B2S1(V) 0.765
O2B1S1(V) 0.155
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 192
SHRTFT1(%) 0.8
LONGFT1(%) 5.5
SHRTFT2(%) -1.6
LONGFT2(%) 5.5
RPM(/min) 808
VSS(mph) 0
SPARKADV() 16
IAT(F) 66
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.100
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.645
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.180
O2B1S1(V) 0.080
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 192
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) -3.9
LONGFT2(%) 5.5
RPM(/min) 784
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.179
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.075
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.110
SHRTFTB2S1(%) 1.6
OBD OBD1
O2B2S1(V) 0.750
O2B1S1(V) 0.780
FUELSYS2 N/A
LOAD_PCT(%) 26.7
ETC(F) 190
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) -3.1
LONGFT2(%) 5.5
RPM(/min) 792
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.130
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.080
SHRTFTB1S1(%) 2.3
O2B2S1(V) 0.045
SHRTFTB2S1(%) 0.8
OBD OBD1
O2B2S1(V) 0.760
O2B1S1(V) 0.815
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 190
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) -3.9
LONGFT2(%) 5.5
RPM(/min) 799
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.585
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.660
SHRTFTB2S1(%) -2.3
OBD OBD1
O2B2S1(V) 0.150
O2B1S1(V) 0.750
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 190
SHRTFT1(%) -3.1
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 782
VSS(mph) 0
SPARKADV() 13
IAT(F) 66
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.780
SHRTFTB1S1(%) -1.6
O2B2S1(V) 0.040
SHRTFTB2S1(%) 1.6
OBD OBD1
O2B2S1(V) 0.755
O2B1S1(V) 0.585
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 190
SHRTFT1(%) -0.8
LONGFT1(%) 5.5
SHRTFT2(%) 1.6
LONGFT2(%) 5.5
RPM(/min) 802
VSS(mph) 0
SPARKADV() 14
IAT(F) 66
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.810
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.790
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.075
O2B1S1(V) 0.095
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 190
SHRTFT1(%) -1.6
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 818
VSS(mph) 0
SPARKADV() 16
IAT(F) 66
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.590
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.035
SHRTFTB2S1(%) 0.0
OBD OBD1
O2B2S1(V) 0.340
O2B1S1(V) 0.085
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 190
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 784
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.505
SHRTFTB1S1(%) -1.6
O2B2S1(V) 0.730
SHRTFTB2S1(%) -3.9
OBD OBD1
O2B2S1(V) 0.040
O2B1S1(V) 0.130
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 190
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) 3.1
LONGFT2(%) 5.5
RPM(/min) 811
VSS(mph) 0
SPARKADV() 14
IAT(F) 66
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.720
SHRTFTB1S1(%) -1.6
O2B2S1(V) 0.080
SHRTFTB2S1(%) 0.8
OBD OBD1
O2B2S1(V) 0.775
O2B1S1(V) 0.120
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 192
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) -5.5
LONGFT2(%) 5.5
RPM(/min) 770
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.080
SHRTFTB1S1(%) 0.0
O2B2S1(V) 0.105
SHRTFTB2S1(%) 0.8
OBD OBD1
O2B2S1(V) 0.315
O2B1S1(V) 0.790
FUELSYS2 N/A
LOAD_PCT(%) 27.5
ETC(F) 192
SHRTFT1(%) -1.6
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 796
VSS(mph) 0
SPARKADV() 16
IAT(F) 66
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.095
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.045
SHRTFTB2S1(%) -0.8
OBD OBD1
O2B2S1(V) 0.405
O2B1S1(V) 0.115
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 192
SHRTFT1(%) -0.8
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 812
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.130
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.745
SHRTFTB1S1(%) -2.3
O2B2S1(V) 0.125
SHRTFTB2S1(%) 2.3
OBD OBD1
O2B2S1(V) 0.755
O2B1S1(V) 0.760
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 192
SHRTFT1(%) 1.6
LONGFT1(%) 5.5
SHRTFT2(%) 0.0
LONGFT2(%) 5.5
RPM(/min) 808
VSS(mph) 0
SPARKADV() 14
IAT(F) 66
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.085
SHRTFTB1S1(%) 3.9
O2B2S1(V) 0.615
SHRTFTB2S1(%) -2.3
OBD OBD1
O2B2S1(V) 0.105
O2B1S1(V) 0.090
FUELSYS2 N/A
LOAD_PCT(%) 26.7
ETC(F) 194
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) -3.1
LONGFT2(%) 5.5
RPM(/min) 804
VSS(mph) 0
SPARKADV() 16
IAT(F) 66
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.135
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.545
SHRTFTB2S1(%) -2.3
OBD OBD1
O2B2S1(V) 0.090
O2B1S1(V) 0.415
FUELSYS2 N/A
LOAD_PCT(%) 26.7
ETC(F) 194
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) 0.0
LONGFT2(%) 5.5
RPM(/min) 780
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.085
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.040
SHRTFTB2S1(%) -0.8
OBD OBD1
O2B2S1(V) 0.480
O2B1S1(V) 0.105
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) -1.6
LONGFT1(%) 5.5
SHRTFT2(%) -3.9
LONGFT2(%) 5.5
RPM(/min) 789
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.110
SHRTFTB1S1(%) 3.1
O2B2S1(V) 0.760
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.050
O2B1S1(V) 0.150
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) 3.1
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 806
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.080
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.120
SHRTFTB2S1(%) 2.3
OBD OBD1
O2B2S1(V) 0.775
O2B1S1(V) 0.810
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) 1.6
LONGFT1(%) 5.5
SHRTFT2(%) -4.7
LONGFT2(%) 5.5
RPM(/min) 790
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.130
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.705
SHRTFTB1S1(%) -2.3
O2B2S1(V) 0.735
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.045
O2B1S1(V) 0.110
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) 1.6
LONGFT2(%) 5.5
RPM(/min) 778
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.115
SHRTFTB1S1(%) 3.1
O2B2S1(V) 0.075
SHRTFTB2S1(%) 0.8
OBD OBD1
O2B2S1(V) 0.285
O2B1S1(V) 0.075
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) 3.1
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 813
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.080
SHRTFTB1S1(%) 2.3
O2B2S1(V) 0.720
SHRTFTB2S1(%) -3.9
OBD OBD1
O2B2S1(V) 0.050
O2B1S1(V) 0.705
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 194
SHRTFT1(%) 0.8
LONGFT1(%) 5.5
SHRTFT2(%) -3.1
LONGFT2(%) 5.5
RPM(/min) 816
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.148
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.185
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.295
SHRTFTB2S1(%) -1.6
OBD OBD1
O2B2S1(V) 0.375
O2B1S1(V) 0.760
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 194
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) -1.6
LONGFT2(%) 5.5
RPM(/min) 799
VSS(mph) 0
SPARKADV() 14
IAT(F) 66
MAF(lb/min) 1.130
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.595
SHRTFTB1S1(%) 0.0
O2B2S1(V) 0.050
SHRTFTB2S1(%) 0.0
OBD OBD1
O2B2S1(V) 0.045
O2B1S1(V) 0.205
FUELSYS2 N/A
LOAD_PCT(%) 26.7
ETC(F) 192
SHRTFT1(%) -0.8
LONGFT1(%) 5.5
SHRTFT2(%) -1.6
LONGFT2(%) 5.5
RPM(/min) 791
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.755
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.145
SHRTFTB2S1(%) -0.8
OBD OBD1
O2B2S1(V) 0.490
O2B1S1(V) 0.730
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 192
SHRTFT1(%) -1.6
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 5.5
RPM(/min) 796
VSS(mph) 0
SPARKADV() 15
IAT(F) 68
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.085
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.085
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.045
O2B1S1(V) 0.130
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 192
SHRTFT1(%) 0.0
LONGFT1(%) 5.5
SHRTFT2(%) 2.3
LONGFT2(%) 5.5
RPM(/min) 805
VSS(mph) 0
SPARKADV() 14
IAT(F) 68
MAF(lb/min) 1.118
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.660
SHRTFTB1S1(%) 1.6
O2B2S1(V) 0.660
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.055
O2B1S1(V) 0.795
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 190
SHRTFT1(%) 0.8
LONGFT1(%) 5.5
SHRTFT2(%) -3.1
LONGFT2(%) 5.5
RPM(/min) 819
VSS(mph) 0
SPARKADV() 14
IAT(F) 68
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.660
SHRTFTB1S1(%) -2.3
O2B2S1(V) 0.380
SHRTFTB2S1(%) -2.3
OBD OBD1
O2B2S1(V) 0.595
O2B1S1(V) 0.810
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 190
SHRTFT1(%) -3.1
LONGFT1(%) 5.5
SHRTFT2(%) 0.0
LONGFT2(%) 5.5
RPM(/min) 803
VSS(mph) 0
SPARKADV() 15
IAT(F) 68
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.760
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.755
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.040
O2B1S1(V) 0.080
FUELSYS2 N/A
LOAD_PCT(%) 26.7
ETC(F) 190
SHRTFT1(%) 3.1
LONGFT1(%) 5.5
SHRTFT2(%) 3.1
LONGFT2(%) 5.5
RPM(/min) 815
VSS(mph) 0
SPARKADV() 12
IAT(F) 68
MAF(lb/min) 1.106
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.700
SHRTFTB1S1(%) -1.6
O2B2S1(V) 0.725
SHRTFTB2S1(%) -3.9
OBD OBD1
O2B2S1(V) 0.360
O2B1S1(V) 0.095
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(F) 190
SHRTFT1(%) 0.8
LONGFT1(%) 5.5
SHRTFT2(%) -0.8
LONGFT2(%) 5.5
RPM(/min) 797
VSS(mph) 0
SPARKADV() 14
IAT(F) 68
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.085
SHRTFTB1S1(%) 0.8
O2B2S1(V) 0.710
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.040
O2B1S1(V) 0.300
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 190
SHRTFT1(%) 1.6
LONGFT1(%) 5.5
SHRTFT2(%) -1.6
LONGFT2(%) 5.5
RPM(/min) 806
VSS(mph) 0
SPARKADV() 13
IAT(F) 68
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.720
SHRTFTB1S1(%) -3.1
O2B2S1(V) 0.085
SHRTFTB2S1(%) -1.6
OBD OBD1
O2B2S1(V) 0.070
O2B1S1(V) 0.100
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 190
SHRTFT1(%) 4.7
LONGFT1(%) 5.5
SHRTFT2(%) -0.8
LONGFT2(%) 5.5
RPM(/min) 823
VSS(mph) 0
SPARKADV() 14
IAT(F) 68
MAF(lb/min) 1.118
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.090
SHRTFTB1S1(%) 3.1
O2B2S1(V) 0.060
SHRTFTB2S1(%) 0.8
OBD OBD1
O2B2S1(V) 0.770
O2B1S1(V) 0.310
FUELSYS2 N/A
LOAD_PCT(%) 27.5
ETC(F) 190
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) -3.9
LONGFT2(%) 5.5
RPM(/min) 789
VSS(mph) 0
SPARKADV() 17
IAT(F) 68
MAF(lb/min) 1.106
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.080
SHRTFTB1S1(%) 3.9
O2B2S1(V) 0.070
SHRTFTB2S1(%) 2.3
OBD OBD1
O2B2S1(V) 0.770
O2B1S1(V) 0.820
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 192
SHRTFT1(%) -3.9
LONGFT1(%) 5.5
SHRTFT2(%) -5.5
LONGFT2(%) 5.5
RPM(/min) 774
VSS(mph) 0
SPARKADV() 15
IAT(F) 68
MAF(lb/min) 1.130
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.115
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.085
SHRTFTB2S1(%) 1.6
OBD OBD1
O2B2S1(V) 0.750
O2B1S1(V) 0.080
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 192
SHRTFT1(%) 0.8
LONGFT1(%) 5.5
SHRTFT2(%) 0.0
LONGFT2(%) 5.5
RPM(/min) 793
VSS(mph) 0
SPARKADV() 13
IAT(F) 68
SPARKADV() 15
IAT(F) 68
MAF(lb/min) 1.136
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.515
SHRTFTB1S1(%) -1.6
O2B2S1(V) 0.195
SHRTFTB2S1(%) -0.8
OBD OBD1
O2B2S1(V) 0.135
O2B1S1(V) 0.095
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 194
SHRTFT1(%) -1.6
LONGFT1(%) 5.5
SHRTFT2(%) -3.1
LONGFT2(%) 5.5
RPM(/min) 806
VSS(mph) 0
SPARKADV() 13
IAT(F) 68
MAF(lb/min) 1.179
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.765
SHRTFTB1S1(%) -3.9
O2B2S1(V) 0.660
SHRTFTB2S1(%) -6.3
OBD OBD1
O2B2S1(V) 0.030
O2B1S1(V) 0.085
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 194
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) 0.8
LONGFT2(%) 3.1
RPM(/min) 795
VSS(mph) 0
SPARKADV() 13
IAT(F) 68
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.270
SHRTFTB1S1(%) -0.8
O2B2S1(V) 0.570
SHRTFTB2S1(%) -2.3
OBD OBD1
O2B2S1(V) 0.225
O2B1S1(V) 0.085
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) 1.6
LONGFT1(%) 5.5
SHRTFT2(%) -2.3
LONGFT2(%) 3.1
RPM(/min) 781
VSS(mph) 0
SPARKADV() 15
IAT(F) 68
MAF(lb/min) 1.130
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.085
SHRTFTB1S1(%) 2.3
O2B2S1(V) 0.480
SHRTFTB2S1(%) 0.8
OBD OBD1
O2B2S1(V) 0.130
O2B1S1(V) 0.780
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) -0.8
LONGFT1(%) 5.5
SHRTFT2(%) 0.8
LONGFT2(%) 3.9
RPM(/min) 796
VSS(mph) 0
SPARKADV() 15
IAT(F) 66
MAF(lb/min) 1.160
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.815
SHRTFTB1S1(%) -2.3
O2B2S1(V) 0.160
SHRTFTB2S1(%) 3.9
OBD OBD1
O2B2S1(V) 0.770
O2B1S1(V) 0.470
FUELSYS2 N/A
LOAD_PCT(%) 28.2
ETC(F) 198
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) 1.6
LONGFT2(%) 3.9
RPM(/min) 800
VSS(mph) 0
SPARKADV() 13
IAT(F) 66
MAF(lb/min) 1.167
TP(%) 19.6
O2S B1S1---B2S1---
O2B1S1(V) 0.780
SHRTFTB1S1(%) -3.1
O2B2S1(V) 0.755
SHRTFTB2S1(%) -3.1
OBD OBD1
O2B2S1(V) 0.055
O2B1S1(V) 0.445
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(F) 198
SHRTFT1(%) -2.3
LONGFT1(%) 5.5
SHRTFT2(%) -0.8
LONGFT2(%) 3.9
RPM(/min) 810
VSS(mph) 0
SPARKADV() 13
IAT(F) 68
MAF(lb/min) 1.197
Old 04-14-2013, 03:38 PM
Wolfboro's Avatar
Based on the ball-park figures I wrote earlier ;
I see there is a slight deviation at Long Term Fuel Trim 1 and 2 (LongFT1 @ -14% and LongFT2 @ - 12.5% ) . Both of these values are slightly out of range (normal should be between +10% and - 10 % ) .
Also one of the oxygen sensors (O2B2S1 - Bank-2 , driver side ) has a barely acceptable 0.175 (yet lower than the optimum reading ) .
It is the easy part till here . From here on, it is going to take a lot of computer research (especially @ you-tube ) see what kind of corrective action is required ( other drivers with similar symptoms) . This kind of diagnostic work is going to take some patience and time , hang in there .
Good luck,
PS. I presume you checked for pending codes and emission test readiness lights and there was "no clue" at those departments ( like a clue pointing at cylinder number ).
Did you resolve your "vacuum leak issue " for sure ? if not , you may have to do it before anything else .
Old 04-14-2013, 03:42 PM
I also had a On board diag test failure. I dont know what it means.
Test $41 Data
MOD: $10
MEAS: 5
MAX: ----
MIN: FCC80
STS: FAIL
Old 04-14-2013, 04:00 PM
i just capped off the vac solenoid as seen in the 2cnd photo. when i plug the vac solenoid to 12v bat charger it moves as if it wants to work but no cigar. how do i test the plug on the firewall?
SM
Old 04-14-2013, 04:24 PM
Wolfboro's Avatar
A quick search says :
41 oxygen sensor circuit indicates system always lean
I took a quick look at the live data you downloaded later on . Some seems to be OK . and some appears to have see-saw values with O2 sensors and fuel trims.
If I were you, I would check vacuum-leak first (all the hoses, that includes PCV hoses -both passenger side and driver side - especially 90-degree elbow on throttle on pass. side ) . Another vacuum related area is EGR valve (its hose and diaphragm ).
These are all no-cost DIY items .
Good luck,
Old 04-14-2013, 07:58 PM
OH KAY I pray this is my last question. I hooked up the fuel pressure gauge, it was at 35 at idle. when i disconected the vac hose to the fuel regulator the pressure gauge did not budge. I watched a u toob vid and I recall the guy saying it should gain a few pounds but am not sure. I wanted to check with the pros before I bought any more parts (fuel regulator).
SM
Old 04-14-2013, 10:08 PM
Another Q, there is a green vac line that connects to the EGR valve. Does that green hose connect to the fuel pressure regulator?
SM
Old 04-15-2013, 11:20 AM
Wolfboro's Avatar
Here is practical testing for "pressure regulator " from V-10 archives .
Fuel pressure should be 28-30 psi at idle, 38-40 psi with vacuum disconnected at the regulator.
Disconnect the vacuum at the regulator and watch the gauge. If it doesn't change, and there is vacuum on that hose, the regulator is obviously bad.
The other side of the coin is , IF there is no vacuum on that hose ( as in a vacuum leak somewhere in the system ) , that is not the fault of pressure regulator .
My 2003 has a different EGR system , so I can't help with the hose question.
Good luck,
<!-- / message --><!-- sig -->
89 F250 surges especially when cold 2frosty 1987 - 1996 F150 & Larger F-Series Trucks 2 06-21-2011 04:35 PM
5.4 surges under load jimjoebob99 Modular V8 (4.6L, 5.4L) 5 07-02-2010 07:12 AM
5.4 surges under load jimjoebob99 1999 to 2016 Super Duty 6 06-15-2010 07:57 AM
Surge/stumble and smoke on accel, but no codes spinge 6.0L Power Stroke Diesel 26 12-19-2009 12:34 PM
Engine misses, surges, backfires - Any ideas? markinms Ranger & B-Series 11 11-02-2003 02:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
