Speedo, Elec. Shift Control & Radio not working
so i get in my truck to go run an errand and notice it is shifting really hard. I then notice the speedo and odometer are not working. THEN I notice the radio is out as well.
I think to myself....a fuse? so the fuses get replaced since they are on two separate ones.
nothing.....all are still out.
any ideas?
any ideas?
If it weren't for the radio and odometer not working, I'd say to start diagnosing the PSOM and VSS, but it seems as though the issue isn't going to be anything to do with that.
Maybe there's a short somewhere that's blowing a fuse immediately after you replace it? Have you checked for voltage at the #8 and 18 fuses?
I had the same issue with my 95, and the dome lights were out as well. My problem was I had a short in the wiring to the sun visor courtesy lights, which are on the same circuit as the dome lights.
myfifty
04-01-2013 02:27 PM
James Patrick Harris
01-11-2013 08:36 AM
blackbikebmx
07-09-2008 01:34 AM
Dean123
02-08-2006 08:29 PM
