1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Fuel filter cap
Old 04-10-2013, 06:49 PM
baker51's Avatar
baker51
baker51 is offline
Fuel filter cap
Hi i have a 2003 Ford f 250 turbo diesel 7.3lt V/8,is there a tool to undo the cap on the fuel filter as i have problems every time i service the truck.
Cheers
Baker
Old 04-10-2013, 07:18 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
It depends on if you have the OEM cap or not. There is this tool:
Great deal on KD Tools 3526 at ToolTopia.com
Someone makes a billet aluminum cap removal tool but I don't remember who that was...
An oil filter and/or strap wrench works as well.
You may also have one of the aftermarket integrated filter with cap. Those kinds are hard to remove because sometimes you really have to crank them down to get them to seal. I prefer the OEM style cap and filter.
FORD OEM FUEL CANISTER LID with BEVELED O-RING 1999 - 2003
Racor PFF4596 Replacement Fuel Filter Element for 1999-2003 Ford 7.3L Diesel
With these parts, I usually just tighten and loosen by hand. No tools needed. It's not really recommended to crank then down too tight because the fuel bowl can split. All you have to do is get the o-ring to seal which doesn't really require that much holding power.
Good luck!
Old 04-10-2013, 11:53 PM
Nsaan's Avatar
Nsaan
Nsaan is offline
I use a big pair of filter pliers to get the factory Ford lid off, then I install the filter that Autozone sells I believe it is a 831, it has the Wix number on the box also, it comes with the new lid that has a recess in the lid for a 1/2" drive, I have had no problems with them ever leaking.
Funny thing is when I searched for just the fuel filter lid, it costs more then the whole filter assembly.
I kept my old ford lid, don't know why, I just did, that was almost 4 years ago and it is still sitting in the shelf.
Old 04-11-2013, 04:51 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Running with the Wix filter and cap and your asking for problems.
Most caps with the 1/2" slot tend to crack from that.
Your going to say that you have not had problems in the 4 years.
Just lucky is all I can say. Enough people have had problems wit the
aftermarket filtres and caps that it's a good way to have problems.
Is saving a few $$ worth a $12,000 engine?
Sean
Old 04-11-2013, 09:10 AM
Nsaan's Avatar
Nsaan
Nsaan is offline
Sean
Sean
Yes, I have run them for many years without any problems, funny thing is since I only buy diesel from known good sources, the filters hardly ever look dirty on all but my 450, and that is because I need to do injectors on that truck, but that is only from the oil that gets in the fuel. Since the filter comes with a new cap, it is replaced every time the filter is replaced, which for me is 10K miles or every other oil change so it is on the truck for 6 months at most, usually less. I know where your going with this, if I had a 6.0 truck I would not run anything other then a factory filter, but this is not a 6.0.... or a $12K motor. I can buy used motors all day long for 2500 bucks and swap it out. I paid less then that for both of my Fords combined.
Old 04-11-2013, 02:47 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I have got to quit posting when I am tired. For some reason I was
thinking I was still in the 6.0 Forum
I do feel any time the filter company has to make it fit because there
filter will not fit in the stock housing it not a good option. I am not a fan
of fit-em-all parts.
That being said I will still use a Fram filter on any gas engine so far.
Sean
CobraBern
11-15-2010 08:12 AM
tndiesel
11-06-2007 08:12 AM
TJ Shaw
06-14-2007 09:08 PM
Mindstream
01-08-2007 03:26 PM
Hotwheelbill
04-20-2006 05:22 AM
Quick Reply: Fuel filter cap
