Help with my 72 F250 carb - Ford Truck Enthusiasts Forums
S. California Chapter Join Chapter, Leader: wpnaes
Old 04-10-2013, 12:47 PM
irishredcoat's Avatar
irishredcoat irishredcoat is offline
irishredcoat is starting off with a positive reputation.
My truck has problems starting. It will turn over after a few seconds, idle rough than stall out. I do this 2-3 times and eventually it will idle correctly and stay running. I read a post and one member suggested to a guy that it was an issue with the choke. I am not very knowledgeable about engine repair but I am a fast learner. Any info you need to help me out, I will do my best to provide. Thanks
Old 04-10-2013, 02:32 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
There is usually a thermostatic, bi-metallic spring that shuts the choke mechanism when it's cold, and opens when warm.
The choke shaft gets crudded-up, along with the little inter-connecting rods, and needs to be cleaned.
This is the job of an aerosol can of "Choke Cleaner", available at your favorite Pep Boys or similar.
Go get a can and report back with the carb's "make". It should be Motorcraft or Holly (or similar).
Pick up a pair of nitrile gloves somewhere along the way, too.
We'll get you through this.
If you're close enough to one of us, maybe someone will drop by with a hands-on tutorial.
Pop
Old 04-10-2013, 03:04 PM
Thanks Pop and nice to meet you. I know its a motorcraft but not sure which one. It has the housing for an electric choke (some of it) but it was converted to a manual choke and its home made. I was just researching the MC 2150 and learning about the different parts of the carb so what your saying sounds familiar but I will have to look at a diagram. I will take a picture of it when I get home tonight. I live in Riverside. Thanks again
Old 04-10-2013, 03:32 PM
If you know how to use them, manual chokes are to be preferred!
That goes for a LOT of stuff, btw!
Not sure who we've got in the Riverside area that can assist, but SOMEONE will stumble along who knows carbs.
Otherwise, we'll do it here, over the interwebz.
First thing you'll want to do is pull off the air cleaner so we can see what we're dealing with.
Got the aerosol can in hand?
Pop
Old 04-10-2013, 10:03 PM
I wont be able to work on her until this Saturday, I work 10+ and i get home too late to crank her up or anything. I will check back in periodically over the next few days and come Saturday I will be ready to proceed. I didnt expect anyone to answer so fast, Your Awesome Pop!
Old 04-11-2013, 02:18 AM
wpnaes's Avatar
wpnaes wpnaes is online now
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Yeah, we like to keep 'Awesome Pop' around for these types of challenges!
High Idle Question pog23 6.4L Power Stroke Diesel 7 09-04-2010 05:25 PM
curb idle good in gear idle bad spuds0828 1978 - 1996 Big Bronco 2 09-30-2009 01:26 AM
Fast Idle problem? nsaikia Fuel Injection, Carburetion & Fuel System 4 04-28-2006 08:11 AM
auxillary idle control computer kinchaser Ford Inline Six, 200, 250, 4.9L / 300 3 07-24-2003 08:47 PM
300-6 idle problems Boss_358 Ford Inline Six, 200, 250, 4.9L / 300 11 08-11-2001 01:16 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
