Looking for V10 manual transmission fluid change information
I want to change the transmission fluid on my 2006 F250 V10 with the manual transmission. In my mind it should be a simple thing to do, but I am not having any luck with a search of step my step directions and help. If it were an automatic there are links abound, but notta on the manual transmission.
I only have 69,000 miles on the truck, but don't see it going anywhere in the future....I plain like it too much.
Anyone lead to me a good source of information, or in a position to educate me?
There are two plugs in the manual trans. On the side of the trans is the fill plug. On the bottom is the drain plug.
Remove the FILL plug first. Then remove the drain plug. When it is done draining replace the drain plug.
Pump synthetic MERCON V in through the fill plug. When it starts to run out the fill plug the trans is full. Install the fill plug.
I bought a hand pump for less than $10 at my local auto parts store that works great for this.
The following users liked this post:
blockmanjohn
11-16-2009 04:16 PM
boggerted
07-16-2009 04:47 AM
makthenif
11-18-2006 09:09 AM
msujon71
08-16-2001 02:16 AM
