Ok parts have arrived what else - Ford Truck Enthusiasts Forums
Old 04-09-2013, 10:49 PM
awillo0406's Avatar
awillo0406 awillo0406 is offline
awillo0406 is starting off with a positive reputation.
OK my yellow tape arrived today!! (First Time)
Here is what is planned as of now. I have all new IC boots (old one's extremely oily), a turbo re-install kit (existing one is leaking), all new CCV O-rings (not positive if I'm just going to clean and put back or run out the back), EBP sensor tube clean/replace. I will not know if anything else is leaking until I can get the IC tubes and spider out of the way. I'm also planning on cleaning out the IC. And I'm planning on doing the foil delete.
Are there any other items I need to check and look at while I'm trying to make it last.
________________________
e99, 250 extended cab, LWB, edge programmer, original exhaust w/catalytic converter deleted.
Old 04-09-2013, 11:41 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is online now
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
After you get the IC pipes and spider off spray the valley down really good with simple green and rinse it off real good. And watch for more leaks.
Old 04-09-2013, 11:56 PM
DND58's Avatar
DND58 DND58 is offline
DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.
Look for leaks at up pipes and turbo pedestal while your in there.
There is a fuel line that runs on the passenger side that is held by a bracket that could use some protection. Robin covers it here.
http://www.ford-trucks.com/forums/10...-for-e99s.html
With all that stuff out of the way, it's a great time to look under the valve covers, re-torque and 50 cent mod per Chris here.
http://www.ford-trucks.com/forums/92...lve-cover.html
That's a couple easy,cheap items that may save headaches down the road. Others will be along.
Old 04-10-2013, 06:08 AM
awillo0406's Avatar
Spraying the motor down with simple green then rinsing it off might be a little hard. The only garage I have to work in is in my buddy's basement. Don't think his wife would be too happy if I ruin it.
All ready planning on pulling the turbo and pedistal and replacing everything there. Not positive EBV is leaking or not. Will check all of those items once I get it off.
How do I know if I'm leaking at the up pipes?
Also forgot to mention that I bought the S&B intake and plan on doing the zoodad at the same time.
Old 04-10-2013, 06:32 AM
awillo0406's Avatar
If i'm already under the VC should I worry with changing out the injector o-rings? Or how would I know if they where bad?
I didn't purchase a new pedistal, if the EBV is leaking should I just delete it? If so what does this intail?
Old 04-10-2013, 08:56 AM
DND58's Avatar
If the up pipes are leaking, you will see signs of soot around the baby butt. Be aware if you remove the turbo, you may disturb the OEM seal there. See post # 9 from Ken in the attached link.
http://www.ford-trucks.com/forums/11...questions.html
I don't believe I would mess with injector o-rings unless you were having some kind of problem, hard starting, ... How many miles on the truck? How's it run, smoke, power,..? Hopefuly others will chime in.
My pedestal leaked. I used a rebuild kit from Guzzle because I use the valve as exhaust brake. You can plug you pedestal or buy a non EBPV pedestal.
Old 04-10-2013, 11:07 AM
awillo0406's Avatar
My truck deffinetly has a hard start problem, but that is because the PCM sends nothing to the GPR for now I will use a momentary switch to fix.
As for the up pipes do I need to order the felpro gaskets for rehooking them to the turbo. Deffinetly can't afford to purchase bellowed up pipes now.
And my oil leak (hopefully back side of turbo) is getting worse and can't wait any longer.
Old 04-10-2013, 11:25 AM
guitarpicr's Avatar
guitarpicr guitarpicr is offline
guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.
Are you doing plenumn inserts also ? I would do these also - Makes it a much tighter fit on the plenumns
Old 04-10-2013, 11:37 AM
awillo0406's Avatar
Best I can find is that no one has plenum inserts for a e99 truck only the 99.5 and ups
Old 04-10-2013, 11:45 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
yup...plenum inserts and "cabinet kit" from RiffRaff
Old 04-10-2013, 12:14 PM
awillo0406's Avatar
<table border="0" cellSpacing="0" cellPadding="5"><tbody><tr><td vAlign="top" rowSpan="5" align="center"></td><td vAlign="top" align="left"><form method="post" name="FORM" action="http://www.riffraffdiesel.com/mm5/merchant.mvc?">Quantity in Basket:None
Code: RDPPRI
Price: $34.58
</form></td></tr><input name="Action" value="ADPR" type="hidden"><input name="Screen" value="PROD" type="hidden"><input name="Store_Code" value="RRD" type="hidden">only thing I can find and this is from Riffraff very last line says only for 99.5 and up
<tr><td></td></tr><tr><td vAlign="top" align="left"><table border="0"><tbody><tr><td>SS T-Bolt Clamp : </td><td vAlign="middle"><select name="Product_Attributes[1]:value"><option selected="" value="">None</option><option value="2" AttribCost="8.00" RegPrice=""> 2 Clamps +$8</option><option value="4" AttribCost="15.00" RegPrice=""> 4 Clamps +15</option><option value="None" AttribCost="0.00" RegPrice=""> None</option></select></td></tr><input name="Product_Attributes[1]:code" value="Clamps" type="hidden"><input name="Product_Attribute_Count" value="1" type="hidden"></tbody></table></td></tr><tr><td></td></tr><tr><td vAlign="middle"><table border="0" cellSpacing="0" cellPadding="4" width="300" align="right"><tbody><tr><td>
Quantity:<input name="Quantity" value="1" size="4" type="text">
</td><td>
<input border="0" alt="Add To Basket" src="graphics/00000001/justadd.gif" type="image">
</td></tr><tr><td> </td><td>
<input border="0" name="registry" align="right" src="graphics/add2registry.gif" type="image">
</td></tr></tbody></table></td></tr><tr><td vAlign="middle" colSpan="2" align="left"></td></tr><tr><td vAlign="middle" colSpan="2" align="left"> These billet 7075 Aluminum plenum inserts are a Riffraff Diesel original design and are patent pending. They are made to allow you to clamp down as hard as needed with T-bolt clamps so that you don't have any boost leaks. Fix your bent and crushed stock plenums with our Inserts as well. This is a budget friendly option to buying full billet plenums. Easy install, no special tools needed.
These were designed so as to add the least restriction possible while providing more than adequate structure for clamping. The Plenum Inserts have been machined to within .164" of the OEM diameter so there will not be any measurable affect on EGT's or cfm flow.
These are sold in a pair.
Riffraff Diesel Performance is committed to 100% Made in the USA on this product. All materials are from USA resources. Every machining step is performed in the USA. Every component is assembled in the USA.
Fitment: 99.5-03
Old 04-10-2013, 02:26 PM
awillo0406's Avatar
Does the valve covers have to be torqued back to a certain spec?
Also, should I go ahead and clean the IPR while i'm working on it?
And how do you drain the HPOP when changing the oil? I know the shop I used to take it too just drained the bottom side only.
Adam
Old 04-10-2013, 03:50 PM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Valve cover just tight, not too tight. To be technical.
Old 04-10-2013, 05:30 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
If you are that far in I'd reseal the intake plenums
Old 04-10-2013, 05:43 PM
huntke's Avatar
huntke huntke is offline
huntke is starting off with a positive reputation.
I just had my turbo off for a rebuld and discovered leaky uppipes after i got it off. The early 99 bellowed are $800 .... I had the money for them but couldn't justify the price for what it was. I welded up the places where the original doughnuts wore into the pipes and ground it smooth, got the oversized ones and put it back together. Was a pain getting all ligned up again, hope it lasts!
Got another question, Irate S468 kit Tim Shultz 1994.5 - 1997 7.3L Power Stroke Diesel 38 07-19-2013 03:18 AM
Intercooler removal 77-250 6.0L Power Stroke Diesel 1 10-19-2010 09:27 PM
14PSI Boost ?? ChunderDownUnder 1999 - 2003 7.3L Power Stroke Diesel 18 05-12-2009 05:01 AM
IC Pressure Test - Limits?? F250_ 1999 - 2003 7.3L Power Stroke Diesel 12 01-12-2009 05:25 PM
IC boot change on horizon mjlewis 1999 - 2003 7.3L Power Stroke Diesel 40 04-01-2007 08:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
