1996 Ranger 3.0 with rough idle - Ford Truck Enthusiasts Forums
Old 06-04-2003, 05:28 PM
duke21 duke21 is offline
duke21 is starting off with a positive reputation.
Unhappy 1996 Ranger 3.0 with rough idle
I bought a 1996 Ranger 3.0 from a dealer with 60k miles. It's real clean but after driving a while, I noticed it idles very rough. While waiting at a light, I can feel the truck shaking back and forth. It runs great otherwise. I brought it back within warrantee period 2 times for a total of 6 days. Honda dealer sent it to the local Ford dealer where they replaced the air sensor. They tell me nothing is wrong with it...the computer shows nothing...but it idles exactly the same. Is this normal? Is there anything I can do to smooth the idle? It drives me crazy.
Thanks for any help.
Old 06-04-2003, 05:37 PM
RangerRuss RangerRuss is offline
RangerRuss is starting off with a positive reputation.
Duke 21:
Check the back threads as there have been many with rough idle and other driveability problems. Many have been solved easily others took a little more effort.
First thing that I would check is for any vacuum lines that may have fallen off or are leaking (hiss). Second, check your EGR valve to ensure that it is opening and closing properly. Lastly, with the truck in the complete dark like inside the garage with the lights off, open the hood with the engine running and watch for sparks/arcs from the ignition wires. Could have one or two that are "leaking" to ground.
Keep us posted on your progress.
Russ
Old 06-04-2003, 10:52 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
duke21 ...Welcome to Ford Truck Enthusiasts!
Russ has suggested a good troubleshooting plan.
If you still are having problems after that, you may also want to consider cleaning your MAF and your Idle Air Control Valve.
Please Help, new to me farm truck won't start. frambin 1999 - 2003 7.3L Power Stroke Diesel 59 06-15-2015 09:49 PM
Rough running 390 @ idle 71Goose FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 17 03-24-2014 10:13 PM
Need motor mounts to put a Honda motor in my truck Area351 1967 - 1972 F-100 & Larger F-Series Trucks 37 07-24-2013 07:25 AM
1999 Ranger 4x4 4.0 - TRANSMISSION FILTER & FLUID CHANGE jcoleman777 Ranger & B-Series 4 06-11-2013 08:19 AM
rough idle in 2002 ford ranger 3.0L red ranger Ranger & B-Series 3 02-23-2002 08:06 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1996, 1998, 30, adjust, ford, hoses, idle, problems, ranger, rough, runs, shakes, troubleshooting, v6, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
