HPOP, Radiator Leaks, and Stop Leak? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-09-2013, 02:43 PM
paddler paddler is offline
paddler is starting off with a positive reputation.
I've had a fluid leak for quite a while, and finally concluded that it's engine oil from around the HPOP base. Probably about a quart per 5K miles. It looks like it's coming from the front base of the HPOP, leaking onto the water pump housing, then migrating to the bottom of the pan and fender liner.
I don't have time to take the truck out of service for quite a while, so my immediate options are a) leave it alone and b) try one of the engine oil stop-seal-leak additives. Any wisdom on either approach?
BTW, truck is running well... just returned to service after getting my custom bed project on and usable (not finished... but back in service) and replacing a bent compressor wheel. So I don't think I have any issues with HPOP performance... just a nagging leak.
Similar situation on a new small coolant leak at the bottom driver's side radiator coolant fitting. I'm going to tighten the clamp and hope that's it, but the leak may be the fitting-to-radiator connection. If tightening the clamp doesn't work, are there objections to using radiator stop-leak in these engines?
Thanks in advance for any advice.
Old 04-09-2013, 03:11 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Do NOT use any stop leak style additives.
EVER.
Not for coolant or for oil.
Old 04-09-2013, 04:06 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
Quote:
EVER.
you know some of us make a living working on vehicles and people using that junk makes us more money, changing heater cores, exct. so quit telling people the truth that that stuff is garbage!
Old 04-09-2013, 05:52 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
My brother used to work in automotive cooling system service; they used to call the stuff "Bars Heat", for its uncanny capacity to clog heater cores.
Lower radiator hose? If tightening the clamp doesn't get 'er, drain the radiator and remove the hose and clean up the fitting. Also try a new clamp and/or hose. If it persists, and it's copper, you can have it repaired (soldered). If it's plastic, new rad time.
Old 04-09-2013, 07:43 PM
Talyn's Avatar
Thats bars leak homie. =)
Old 04-09-2013, 09:26 PM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
if the oil is running down the water pump my bet is hpop lower o-ring seal..thats a very large 20min job to replace.the hpop gasket is just an afternoon project.do both at the same time on a sat...its really NOT a big deal.I would repair it correctly..I did exactly that last year..my garage floor on my 322000mi truck is completly dry..leaks are unacceptable. THIS is the first non-race/project vehicle I have ever been obsessed about garaging always.Its pretty cool.
Old 04-10-2013, 01:14 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
It could just be the inspection cover to the HPOP bolt on the front side.
Old 04-10-2013, 01:58 AM
fordman67's Avatar
oohhhh! Glenn,you got me there.I didnt mention that did i...wouldnt that be nice is all.
Old 04-11-2013, 09:27 PM
Thanks, guys
OK guys, I think I see a consensus... no stop-leak in the OBS.
Will tighten the hose clamp this weekend and keep an eye on coolant level.
The HPOP will wait a bit...sounds like nothing bad is going to happen, and I won't have much time for a couple of weeks.
Now I must admit, there IS stop-leak in my 01 Taurus wagon... leaking timing cover seal. 10 hour book job to repair, and my local shop won't touch it- they've had problems making the fix work. So we'll see if the stop-leak works. If not and the leak gets worse and coolant ends up in the oil, well, 40+ mpg from a Jetta Sportwagon TDI manual starts sounding nice.
Oil leak below HPOP Redneckmorton 1994.5 - 1997 7.3L Power Stroke Diesel 2 10-16-2015 10:40 AM
Replaced HPOP No Start CrazyCajun 1999 - 2003 7.3L Power Stroke Diesel 23 09-17-2015 09:33 AM
Coolant Leak! But only after the motor has cooled down, during the night. GormGorm 1987 - 1996 F150 & Larger F-Series Trucks 13 12-25-2014 12:28 AM
HPOP Second Leak Failure wallsy Australia Chapter 12 03-02-2013 05:48 PM
HPOP air test fixxxer-upper 6.0L Power Stroke Diesel 23 02-16-2013 12:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
