2005 F250 6.0 Turbo Diesel with hesitation... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-08-2013, 09:21 PM
rhillman75 rhillman75 is offline
rhillman75 is starting off with a positive reputation.
I bought the 2005 F250 6.0 with 67,000 miles on it last March. It has given me gave me absolutely no problems until now. In the last 2 weeks I have had it plugged in when it was below 32 degrees outside. Otherwise, I just remote started it every morning and let it run for 20 minutes before I left. In the last 2 weeks, I have noticed the same problem whether it is morning, afternoon, or evening and it happens at different times. I will be at a standstill at a stop light, stop sign, or parked in my driveway when this occurs. Sometimes, and like I said, "sometimes", it will hesitate when I give it throttle. It will quickly respond after maybe a second, but the hesitation is still there. It only does this on occasion! I work for a Lucas Oil distributor, so in the winter I ran the "extreme diesel conditioner" through it with a tank of diesel about every other week. I also used the fuel-injector cleaner at every fill up. On "ONE" occasion, and like I said, "ONE" occasion, when it hesitated at a stoplight, I looked in the rearview mirror, and noticed a short burst of white smoke, and then it took off. It has not done that since. I took the EGR off and cleaned it and it seemed okay until 2 days later, then the same hesitation came back, but like I said, at times! I replaced the air filter and since then I have done nothing. I am now being told to check the coolant level in the resevoir. When I un-screwed the cap the cap, there was pressure in there and the fluid was about 1/4 inch low from the line. I was also told to check the filter on top of the block, but I have not gotten that far. Ford says it is the EGR cooler system and wants $2,400 to fix it if that is whats bad! I have "NO" check engine lights! Thoughts???
Old 04-09-2013, 05:03 AM
jdw1's Avatar
jdw1 jdw1 is offline
jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.jdw1 has a great reputation on FTE.
One more thing to check would be the FICM voltage, unless you have done this already.
Do yourself a favor and get some engine monitoring device on your truck asap and learn all the functions it has.
I am running an "Edge Insight", saved me some on the road headaches a couple of years ago in Las Vegas
Also maybe the moderators can move this to the 6.0 forum.
Good luck
Old 04-09-2013, 10:40 AM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Come on over to the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
and post the question again. You will get a better shot at a fix.
Sean
Last edited by powerstroke72; 04-09-2013 at 01:07 PM. Reason: Removed unnecessary info.
Old 04-09-2013, 12:43 PM
Yahiko's Avatar
A tuner is not going to fix the problem.
Let see we can start with the FICM then move on to wrong filter dirty filters.
A dirty fuel filter will do this and also if he does not have the upgraded fuel
pressure regulator spring installed.
Sean
Last edited by powerstroke72; 04-09-2013 at 01:08 PM. Reason: Remove unnecessary info
Old 04-09-2013, 12:52 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Quote:
We can get you through an EGR cooler replacement for a lot less that $2,400, with better parts than OEM if that's really the root cause.<filllllllllllllllllllllllll></filllllllllllllllllllllllll>
Last edited by texastech_diesel; 04-09-2013 at 01:38 PM. Reason: Made relevant again :-X22
Old 04-09-2013, 01:12 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Thanks guys. The unneeded "for sale" ad has been removed and I edited some of your posts since he's gone....they wouldn't make much sense otherwise.
Thanks again.
Old 04-09-2013, 08:08 PM
Yahiko's Avatar
< sheepish grin >
Thanks John
Sean
Old 04-09-2013, 08:14 PM
No, thank you and Bryan for pointing it out.
I appreciate you guys looking out for us in these threads and forums. We can't be everywhere all of the time so we depend on you guys to report posts, etc. when you see things.
Old 04-09-2013, 08:35 PM
Yahiko's Avatar
Does the have a tattletale on it?
Be an interesting idea.
Sean
Old 04-09-2013, 11:48 PM
Okay... that is some interesting replies. We have gone from ideas to check to "ads for sale." So is the best idea to replace the filters to start or ???
Old 04-10-2013, 12:53 AM
Disgruntled Texan
Old 04-10-2013, 03:37 AM
Yahiko's Avatar
Ask for Rusty Axlerod. He has photos of what the right filters and caps look like.
BUT please do come over to the 6.0L Forum.
Sean
Old 04-10-2013, 07:35 AM
Unfortunately, someone saw your thread as an opportunity to try to sell you a used tuner. It's not allowed and the gentlemen in this thread who've been trying to help you were kind enough to point it out. Plain and simple.
The post from that person was removed.
Old 04-10-2013, 04:13 PM
greentree ford greentree ford is offline
greentree ford is gaining momentum as a positive member of FTE.greentree ford is gaining momentum as a positive member of FTE.
That blue spring that you said you ordered regulates your fuel pressure, The problems you say you are having might be fuel pressure related. I say install the blue spring and see if anything changes with you issues.
P2290 Code and Hesitation Question Boats12 6.0L Power Stroke Diesel 6 04-19-2014 02:51 PM
2003 ford ranger 4.0 Hesitation Issue topcop5673 Ranger & B-Series 3 06-22-2011 10:06 AM
2005 6.0 Idle problems kdawson 6.0L Power Stroke Diesel 2 06-07-2011 12:47 PM
MIL and hesitation issues cougar_1987 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 09-01-2009 08:46 PM
Bronco hesitation zstar5000 Bronco II 5 12-02-2006 11:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
