best trans for conversion - Ford Truck Enthusiasts Forums
Old 04-08-2013, 06:45 PM
94flaresideon20s's Avatar
94flaresideon20s 94flaresideon20s is offline
94flaresideon20s is starting off with a positive reputation.
i have a 94 150 2wd 5.0 with a 40r70w trans that i keep having issues with so i decided to do a swap. i have a good idea what i will need as far as tranny bellhousing crossmember drivesshaft pedal assembly starter flywheel clutch fork and i know im missing something else. what i found at the junktard was another 94 with a straight six with a 4spd with od. would this be a good trans for the swap. what would be the pros and cons of this trans also is there a better trans for this swap. also i know i need to swap computers would the 4.9 comp work or do i need a 5.0. any help or opionions will help thanks
Old 04-08-2013, 11:14 PM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
You woud need a 5.0 computer for a manual trans truck. I think that tranny you are talking about is the m5od,not a real strong tranny,it might hold up behind a stock 5.0 if you don't thrash it.
5.8 with 4R70W trans?? 94F150SWB 1987 - 1996 F150 & Larger F-Series Trucks 15 12-03-2014 04:53 PM
Can someone point me in the right direction Green Griffin 420 1987 - 1996 F150 & Larger F-Series Trucks 21 05-29-2014 04:56 PM
1994 standard to Automatic swap Scott Stewart 1987 - 1996 F150 & Larger F-Series Trucks 6 11-20-2011 07:55 AM
94 to 89 engine swap frenchy107 1987 - 1996 F150 & Larger F-Series Trucks 2 03-02-2011 01:40 PM
Trans swap renchr56 1978 - 1996 Big Bronco 5 05-29-2006 10:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
