Please Help! truck keeps cutting out, jerking, and sputtering while driving. - Ford Truck Enthusiasts Forums
Old 04-08-2013, 10:28 AM
millertj87 millertj87 is offline
millertj87 is starting off with a positive reputation.
I have a 1995 F150 351 5.8l V8 that act as if it is running out of gas while I'm driving down the road. The issue almost never happens during my morning drive to work but almost always happens on my drive home when it is warmer. It will jerk and shake as if it is about to run out of gas and seems to lose some power. I have duel tanks and the issue happens regardless of what tank I am using. I occasionally can go a day or maybe two without any issues but it is normally an everyday occurrence.
I have replaced the disturber cap and rotor and also put in a new fuel filter. The plugs and wires were replaced about a year ago.
Any ideas or help with this issue would be greatly appreciated.
Trent
Old 04-08-2013, 10:24 PM
chris05 chris05 is offline
chris05 is starting off with a positive reputation.
having same problem ivespent more on parts then the pos is worth. has 276000 miles and runs like brand new of a morning but sure enough on the way home and seems like within a mile of the same spot it spazs out
Old 04-08-2013, 11:11 PM
ford2go's Avatar
ford2go ford2go is offline
ford2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud of
welcome to fte,
You might try spraying some starting fluid as soon as it quits. If it starts then, it could be a fuel problem.
Possibly the pump, or maybe the pressure regulator.
Also, check for spark. The ignition module (TFI) in that era of truck was famous for failing when hot.
It also could possily be the computer -- search on electrolytics or capacitors.
Those have been reported as an issue a number of times.
Note -- this is all info I've learned at FTE -- I've never done a lot of these things-- but, I've read the descriptions many times.
Good Luck,
hj
black smoke, jerking, sputtering, now no start cpye2 1999 - 2003 7.3L Power Stroke Diesel 8 04-25-2016 10:56 AM
Strange, mild (transmission?) jerk issue jwallis 1968-2013 Full Size Vans 0 02-27-2016 04:26 PM
Jerking/Studder Confusion mblanken881 6.0L Power Stroke Diesel 43 01-17-2012 09:27 PM
Need help with water in the fuse panel. Kim's Hipster 1999 to 2016 Super Duty 14 03-23-2011 03:46 PM
Misfire on Cylinder 6? It's not plugs, COP or Injector... Bunggo 1997 - 2003 F150 27 03-25-2010 10:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
