V10 vacuum hose identification? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-07-2013, 10:01 PM
Eric H's Avatar
Eric H Eric H is offline
Eric H has a good reputation on FTE.Eric H has a good reputation on FTE.
My V10 Excursion was running really rough and threw codes P0171 and P0174.
I found the hose in the pics linked below has a hole. When I put my finger over the hole the idle immediately smoothed out.
Does this hose have a name? Part number? I'm trying to find a replacement before the duct tape lets loose that I used as a temporary fix.
http://i.imgur.com/mqQuZVj.png
http://i.imgur.com/w1mGjmX.png
Old 04-08-2013, 09:08 AM
mikeismadness's Avatar
mikeismadness mikeismadness is offline
mikeismadness has a good reputation on FTE.mikeismadness has a good reputation on FTE.mikeismadness has a good reputation on FTE.
Your pics aren't showing up. Is it by the throttle body?
Old 04-08-2013, 09:24 AM
Eric H's Avatar
Covered in duct tape in these pics:
imgur: the simple image sharer
The hose goes from up by the air intake down to the PCV valve.
Old 08-25-2014, 08:34 AM
Fifty4F100's Avatar
Fifty4F100 Fifty4F100 is offline
Fifty4F100 is gaining momentum as a positive member of FTE.Fifty4F100 is gaining momentum as a positive member of FTE.
Now I don't feel so bad about my V10 question not being answered. I have a slight lope when idling, but runs smooth above 1200 RPMs. My V10 is in an F53 motorhome chassis so my air intake doesn't look too much like your trucks. Did you get your problem fixed?
Old 08-25-2014, 09:40 AM
DavidB DavidB is offline
DavidB is gaining momentum as a positive member of FTE.DavidB is gaining momentum as a positive member of FTE.
Your symptom indicates a vacuum leak. This is most likely the hose that the op was looking for:
Amazon.com: Dorman 46025 PCV End Assembly for Ford Truck: Automotive Amazon.com: Dorman 46025 PCV End Assembly for Ford Truck: Automotive
53 F250 frame swap. nathankershaw 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 03-10-2017 08:04 PM
1950 F-1 5.3/60e swap complete lilpanther 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-22-2017 09:02 AM
Where do I jack up the trans to remove the cross member? JaySVX Excursion - King of SUVs 16 07-13-2016 01:15 PM
New toy JaySVX Excursion - King of SUVs 13 06-19-2015 03:11 PM
How to change the thermostat and burp the Ex V-10 with pictures EXv10 Excursion - King of SUVs 32 08-31-2014 11:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
