352 Engine - Ford Truck Enthusiasts Forums
352 Engine
Old 04-07-2013, 09:08 PM
schmiddw schmiddw is offline
schmiddw is starting off with a positive reputation.
352 Engine
I was reading some of the links regarding what years of the 352 engines will fit in a '67 Ford Truck. Is it true that only 352s starting in 65 will fit in a 67? I currently have a 360 that burns a ton of oil, and I'd like to get the original sized engine that came with the vehicle.
Old 04-07-2013, 09:13 PM
rustywheel68 rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
i'm not sure exactly where the cutoff is- but the older FE engines have a different bolt pattern for the engine mounts. you can put a newer motor in an older car...but not an older motor in a newer car.
the cutoff is somewhere pre-65.
Old 04-07-2013, 09:43 PM
67F250RET's Avatar
67F250RET 67F250RET is offline
67F250RET is starting off with a positive reputation.
I have 67 camper special and it has stock FE 352. I pulled the engine for work and I replaced the mounts with stock replacements from LMC.
Old 04-07-2013, 09:53 PM
Mine is also a camper special, are you saying I could possible use an older 352 engine and get mount adapters through LCM? I found a 352 from a 62 Ford with 72,000 miles.
Old 04-07-2013, 11:24 PM
67F250RET's Avatar
No, I wasn't trying to say that. After I reread your question I realized I didn't answer your question... I don't know the answer you're looking for. Good luck
Old 04-07-2013, 11:53 PM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
Quote:
If that is a 352 in a 62 Ford truck it is a transplant. 352 was not available in a 62 truck. What type of 62 is this motor in truck or car.
Old 04-08-2013, 05:35 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
The FE was first introduced in 58 in the Edsel. The early engines used a different mount system, and I am not certain what year the change was made. All 65-76, 352s, 360s, & 390s are identical on the outside, all engine bays from 65-79 are darn near identical, so swapping any FE in those years shouldn't be a concern.
I would like to suggest that your engine isn't burning a ton of oil but rather leaking it. Valve covers and intake manifolds combined with the huge amount of air that is blown through there can leak a ton of oil.
Look under the truck at about the rear of the engine to see if it is all wet down there. I believe without seeing your truck that you have the ol blow out & down thang going on.
Bet the truck still runs good, right???
John
Old 04-08-2013, 06:34 AM
Buzz you are correct the 352 is out of a 1962 car: Galaxie I believe.
Old 04-08-2013, 06:39 AM
Jowilker: Yes the 360 does run well, and it has had that leak pattern behind the engine on the floor. Also when driving I have a nice cloud of blue smoke following me. If it is just leaking oil, what would you suggest for the fix?
Old 04-08-2013, 04:01 PM
dbdbb dbdbb is offline
dbdbb is starting off with a positive reputation.
I had a 390 out of a 64 Galaxie that didn't have the proper motor mount bosses, I had to make up an adaptor for the mounts. So I would say 65 or newer.
Old 04-08-2013, 04:30 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
IIRC, "old" FEs are two-bolt, the latter FEs use three-bolt engine mounts.
What ya got?
Old 04-08-2013, 07:00 PM
67dude 67dude is offline
67dude is starting off with a positive reputation.
schmiddw, Where are you located? I have a running 352 that I pulled out of my 67, Cheap! I'm pretty sure it's the original motor w/engine perches. But ya gotta come and get in. I'm in south Louisiana
Old 04-08-2013, 07:22 PM
jowilker's Avatar
The intake needs to be pulled and resealed, the valve covers need to be pulled, (blocked to be made flat around bolt holes) new gaskets installed and torqued to about 15 in. pounds.
Heck of a lot cheeper than replacing a good engine. IMHO
John
Old 04-08-2013, 08:10 PM
67 dude I about as far away as you can get . . . Northern WI.
Old 04-08-2013, 08:52 PM
here's the info, cut/pasted from here:
FE INFO
Another change to watch out for is the engine mount bolt holes on pre-1965 “FE” blocks. Blocks before 1965 had two-bolt engine mounts while those from 1965 and later had three-bolt engine mounts. This isn’t a problem if you plan on using a 1965 and later block in a pre-1965 vehicle.
Problems abound when using a pre-1965 block in a post-1965 vehicle because some machining and drilling are required.
this thread has a picture of the old-style mount:
332-428 Ford FE Engine Forum: FE engine mounts
truck trkdrvr 1967 - 1972 F-100 & Larger F-Series Trucks 3 06-12-2005 05:41 PM
352 engine any good? Cap'n Tea Bag 1967 - 1972 F-100 & Larger F-Series Trucks 3 02-24-2005 06:25 AM
'67 352cid rangoonred67 1967 - 1972 F-100 & Larger F-Series Trucks 13 12-16-2003 03:04 AM
i have a 67 ford f 100 wid a 352 fe and a c4 tranny drocks67ford 1967 - 1972 F-100 & Larger F-Series Trucks 14 08-21-2003 10:58 PM
67 f250 352 exhaust Dude67 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-20-2003 01:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
